Question about Samsung Color Fixed Security Camera Sod-14c
Need wiring map for RJ11 conector for Samsung SOD-14C camera
I have the same problem - any solution available?
Well good news and bad news if u just got shot ends easy cut end off and copy other end with new rj11 6 pin phone jack.. what im trying to do is give camera secondary 12v power and use the wire in the jack to splice into RCA type connector to work with my old dvr
Posted on Aug 13, 2010
2 Suggested Answers
  • 3 Answers
SOURCE: Need wiring map for RJ11 conector for Samsung SOD-14C camera
I guess this is an ongoing issue with Samsung cameras. Did anyone EVER figure this one out?
Posted on Mar 31, 2010
My 3g isnt working how can i fix it
Check your sim card. If the connectors or only one connector is dirty or oxidised it could cause the trouble. You also could walk in a stroe from your providor and ask if they can help. They have spare sims to test if it is the sim or the phone.
Jul 05, 2014 | Samsung Security Cctv Sod-14c Soc-120...
How do I change connection mode on my galaxy s4 mini with android 4.4.2?
Turn on your phones screen drop down your notification bar and press notification about your phone connected via usb and it gives you two options and one of them its Mtp and second Ftp. Choose Mtp. And thats all
Jun 25, 2014 | Samsung Security Cctv Sod-14c Soc-120...
I need to conenct yamaha rx v420 to Samsung tv
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V420.pdf
Mar 31, 2014 | Samsung Security Cctv Sod-14c Soc-120...
Say the system has 50 ft cablesfo the camers, but u need naybe 15 ft more that can u do?
as long as its cable run, should not be a problem. I went from 50 to 75 for my shop, works fine.but throw some e-tape around the connections.
Mar 19, 2011 | Samsung Color Fixed Security Camera...
How far away can you put a camera? Is there a limit to the length of the cable you can use for this system?
If you are using coaxial cable, a RG59U series cable will allow you about 700 feet or so before the picture starts degrading. RG11U, which has a larger center core, will get about 1000 feet. If you want or need to go further then try hooking up an electric powered signal booster about mid-way of your cable run. If your camera uses a pre-fabricated cable (about the size of a telephone wire) with connectors already installed you will most likely have a much more limited range as these cables are not shielded as well and tend to have greater line loss.
Apr 26, 2010 | Samsung Color Fixed Security Camera...
Jan 20, 2009 | Samsung Color Fixed Security Camera...
Samsung survalance cam sod12c
check on the electronic board inside the camera, you will probably see a few condensator with a "-" on it, just follow the connection and your negatif wire will be connected to it...
cheers
Dec 20, 2008 | Samsung Color Fixed Security Camera...
Samsung Color Fixed Security Camera Sod-14c Logo
1,895 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
