Question about GE WSXH208A Front Load Washer
GE front loader door switch wiring issue
I have a ge wsxh208V1ww. the solenoid died in the door switch. Can't seem to hack a new solenoid into it. Got a "new" electrolux part # 131769245.
Fits the hole but has more wire options 8 vs 6 anyone know where the wires go or do I have the wrong part?
  • Anonymous Dec 23, 2007
    got the same problem with the door switch the solenoid is bad have any idea where i can get one?
  • Loveoption9 Dec 26, 2007
    Guest,
    I ended up putting in the revised door latch that set me back about $55. It has been fine. I made extensions for the wires as they are deep under the face and i didn't want to unstack the set. If you do this ie crimp one foot long wires with male and female spade connecors, be sure to insulate the ends that are floating around loose in the face with tape or shrink tube to avoid arcing or issues. This was an electrolux part with cryptic schemata on the part as to where the wires are connected. the old 2 wire plug does not connect where the new 2 wire plug is located.
    Some possible fixes are availble for the solenoid. First make sure it has continuity. If its open there's no hope. if not it may be that the windings are shorted (also no hope) or that plunger is stuck from the coil swelling or some crud had gotten into it. take it apart and clear the center just enough so the plunger can move. I couldn't find just the solenoid on a like machine in my area, you may have better luck. I did try carving down a solinoid coil from a water valve. got it into the latch but it didn't have the chops to pull the latch closed and it made lots of noise. Good luck
  • 283 Answers
Although there aren't any parts available for them these units ARE repairable. There are places along the sides of the case to unsnap the halves. Just be careful not to unload the spring inside
Posted on Dec 26, 2007
I have a ge washer front loader it does not start. what can i do.
check your door lock. If door lock is okay, issue could be with control board.
Feb 14, 2015 | GE GFWH2400LWW Front Load Washer
Front door leaks
The door gasket is bad this page will help http://www.appliance-repair-it.com/GE-front-loader-washer.html
I know the page says GE front loader but replacing the door gasket is the same.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE front load washer WSXH208v1ww door latch
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
Mar 08, 2009 | GE WSXH208A Front Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Aug 27, 2007 | GE WBVH6240F Front Load Washer
Ice door opener
GE side x side GSS22SGMC stainless steelJust fixed my own problem of jammed ice door. 1. pull the light switch plate off (just under the front bottom edge, push through the holes, pull) 2. unscrew the dispenser assembly, 4 screws, pull the unit out  3. WR62X10020 SOLENOID is in the upper right, unplug the black wires from the board. 4. unscrew the right screw from the door-stop assembly (above the ice door)- pull the plastic out of the solenoid piston 4. unscrew solenoid, 3 screws, from back 5. pull the piston, scrape-sand-file off all rust, then lube with oil 6. scrape off rust from inside,  solenoid with shoving steel wool-file-degreaser to get off rust, then lube 7. reassemble, WORKS!! 8. save 35.00 for new solenoid 9. save repair cost of whole new door (happened!) good luck
Feb 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE WSXH208A Front Load Washer Logo
116 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
