Question about Pedal Car Renault Megane Trophy
I am trying to replace speedo pick up but having trouble locating correctly
Are u a guy scoobydoosoo
Posted on Sep 12, 2009
My harley 1200 c speedo is reading low when I accelarate it drops back and when drop throttle off it goes up to some where near speed until I bring throttle on it drops back to 20 mph Iv cleaned pick
Humm...I would have thought cleaning the pick-up would have solved the problem. Wouldn't hurt to check it again. Also would have been helpful to know the year of the bike! Harley got a bunch of bad speedo/tach assemblies around 1999-2005 (not sure of the exact years/models anymore) but most were replaced under warranty.
Clean your contacts in the electrical connector for the speedo. Spray contact cleaner from an electronics store should be fine. Bad ground will cause these symptoms also, so disassemble and sandpaper all ground wire connectors you can find.
Speed sensor could have went bad too. If all else fails, replace the speedo.
Feb 15, 2015 | Harley Davidson XL 1200 C Sportster Custom...
Speed sensor
The sensor should be in the side of the transmission.
The speedo would stop working, or you would have shifting troubles with the transmission. And you would have a check engine light on with a trouble code for the sensor.
Jul 23, 2013 | Mazda Cars & Trucks
! change a old speed sensor for a new one in my Toyota pick-up 1992 but the speedometer still not work, somebody knows what can be wrong?
it is done completly by electric connection..? on a 92 pick up i belive it still has a speedo cable located at the tail of the tranny.. either the gear is bad or the cable is broken ..if it has cruize control there are two cables one tranny to cruize box and then cruize box to speedo
Feb 21, 2011 | 1992 Toyota Pickup
Need location of pick up coil on engine please
PICK UP COIL FOR WHEEL CYLINDERS? ENGINE coil? ALLECAROMETER PICKPUP coil or master brake cylinder pickup coil for anti skid brakes? or RPM pickup coil for tach and speedo?
Apr 11, 2010 | 1999 Oldsmobile Bravada
Speedo and odo dont work
speed sensor that is located in your transmission well in the back partby differential either sensor or wireing coming from it.
Sep 01, 2009 | 2001 Audi A4
Speedo not working
Try to clean the metal off of the pick up. It may work. If it has metal shavings on it and occasionally works or still doesn't work replace the pick up.it's shot. The speedo still could be bad. but the pick ups go out rather easily. and even if the speedo is bad more than likely the pick up will have to be changed as well. So i would replace the pick up ( if it's got alot of metal shavings on it.
Jun 25, 2009 | 2000 Harley Davidson FLSTC Heritage...
My speedometer keeps failing as in stops working. Ive replaced it 8 times and the last time I changed it was 16 days ago. Its broken again and I was wondering has anyone else been replacing their...
Had a similar problem. Turned out to be the voltage regulator was failing and applying to much voltage to the speedo which cuts out above a certain level. Check it and your stator connection; also had a problem with that connector that may have contributed. Replaced the regulator with a new one and have never had the problem since.
Hope this helps.
95 taurus will not shift out of first gear.
My inlaws Ford Taurus had a similar problem. Is the speedometer working? Their speedometer was working one minute and then the next it wasn't, when it wouldn't shift, the speedo wasn't working either. When the speedo decided to work the transmission shifted. In this case I deduced and researched the speedo sensor. My theory was that if the computer couldn't determine the speed, it wouldn't know when to shift. My research validated my theory and basically stated that when the speedo doesn't tell the computer how fast the car is moving then the computer places the transmission into 2nd gear as a default Safety Mode. I replaced the speedo sensor (located on the backside of the engine on top of the axle with a wire lead pluged into it). When I replaced it their troubles were over. I don't know if this is your problem, but it's something to look into.
Mar 14, 2009 | 1995 Ford Taurus
1998 gsxr 750 speedo problem
if the speedo doesn't work through a cable then it probably works on a electronic sensor.try and trace the wire from the back of the speedo to the sensor and replace the sensor.will more than likely be around the front wheel area or the gearbox.
Mar 05, 2009 | 1996 Suzuki GSX-R 750 T
Pedal Car Renault Megane Trophy Logo
75 people viewed this question
Top Pedal Car Toys Experts
ray gallant
Are you a Pedal Car Toy Expert? Answer questions, earn points and help others
