Question about Toshiba TN55V71 55" Rear Projection Television
Tv shuts off power light blinks
Unplug it and then its works sometimes
  • Toshiba Master
  • 5,138 Answers
One of your STK IC is going Bad,you have 2 of them they will have part number on them for example STK392-110 parts are bigg black ICs replace both of them, also ck capacitors 100uf 250v,if any of them are puffed up on top they are bad.also CK small blue capacitor 2kv feeds to horiout put Transistor.
Posted on Sep 12, 2009
  • kargathblade
    kargathblade Mar 13, 2012
    if any are puffed up on top?
Tv randomly shuts off
next time it shuts down and power light goes out--do the self check.
On front of set press and hold BOTH MENU AND INPUT BUTTONS FOR AT LEAST FIVE SECONDS AND RELEASE BOTH BUTTONS.
Power light (if an error is detected) will blink a two digit code.
Most common is 2 blinks, pause and 2 blinks---set if there is a error code will repeat it at least 5 times.
If you detect a error code, let me know and I will tell you what it means.
SD TECH
Jun 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I push power button and my 1080 series 42 in. mitsubishi big screen shuts right back off.
Most of these sets have a self check feature:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device”(device sometimes is called input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Let me know what you find and I will tell you what it means.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi Televison & Video
TV gets vertical colored lines, then shut off, green blinks conti
Bad Capacitors in the Power Supply could cause this. This Chassis has be famous for bad capacitors through out many boards. If you are not comfortable with working on the unit, and most are not, I would call a professional. The Chassis may need to be sent to Mitsubishi to be refurbished. This is a expensive repair and it would be advisable to call a Mitsubishi Professional to confirm diagnoses. Mitsubishi's Customer Service Number is 1800-332-2119. They also may be willing to help with the cost of repairs.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
May 27, 2009 | Toshiba 42H81 42" Rear Projection...
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Power light starts blinking
replace the vertical ic.having single line is a sign that your vertical ic is need to replace.if the power indicator is blinking is also a sign of defective vertical ic
Feb 06, 2008 | Toshiba 27AF41 27" TV
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Toshiba TN55V71 55" Rear Projection Television Logo
224 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
