Question about Whirlpool LER4634J Electric Dryer
Gas dryer turns but doesn't heat.
I have check the gas line, that is fine. I also disconnected the vent and still no heat any suggestions?
  • Whirlpool Master
  • 3,361 Answers
Verify the glow bar ignitor is coming on. You can do a amp draw test on the ignitor. If 3 amps or less,replace it.
Posted on Sep 12, 2009
Gas dryer wont stay lit
I'm assuming it "starts" to heat but then cuts off. Usually after the first minute of running you can open dryer door and feel heat but after awhile it doesn't heat.
1st, most common problem on a gas dryer not heating is "airflow" . They will "short-cycle" if there isn't near perfect airflow. Turn dryer on and go to outside exhaust vent. It should blow about as hard as you can blow into your hand. If any doubt disconnect dryer vent line from wall and let blow into your laundry room for one cycle and see if it is now working correctly. If it does work correctly when vent line is disconnected at wall you KNOW there is blockage somewhere in your vent line.
2nd, most common problem are gas coils. Easy to replace. 99% of all gas coils are the same so here is the part# (WE04X10020) (write it down.
Below is link where you can purchase appliance parts. Thanks for reading!
Appliance Parts
Feb 07, 2015 | Dryers
The drum turns. It heats up. But only small loads of cotton get dry! We have changed the vent tube. Vacuumed the vent the lint catcher area and around the drum to remove lint and hair. Still not...
A very typical problem with GAS dryers is the soloniod coils that open the gas valve . When the coils are cool they operate just fine,but once the dryer gets warm from running the coils dont open the gas valve wwhen they are warm. If that is what your experiencing,the dryer heats when its cool but doesn't heat when it's been running for a while,the coils on the gas valve will need to be replaced.
GENE
Aug 16, 2011 | Roper RGX4634KQ Gas Dryer
Our Frigidaire Dryer Model FERB7800DSO turns but doesn't heat. I checked the breaker and turned it off and back on with no fix. I see where some say it could be a clogged vent, bad thermostat, or...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Dryers
My kenmore 600 gas dryer dont heat up. gas is on electricity its fine it turn on it works fine but just not heats up.
Disconnect the rear vent off the dryer itself and try again. If heat does work the vent tubing is clogged
Oct 06, 2010 | Kenmore 600 6962 Dryer
My gas dryer is not heating all other funtions are working fine. I disconnected the vent hose and flow is fine. Any sugestions? Igniter or some other sensor and a way to diagnose the problem?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 27, 2010 | LG DLG5988 Gas Dryer
Low heat output
A clogged or partially clogged vent . Especially if vents up thru the wall . If it vents straight out , make sure you have good air flow to the outside . Make sure the vent hose has no sharp kinks also . Try drying a load with the vent hose disconnected from the dryer . If clothes dry fine , that tells you the problem is elsewhere . Normally , a dryer either heats or doesn't heat . A heat for a few minutes then stops heating but continues to run complaint ,would be bad coils on the gas valve .
Jul 19, 2009 | Dryers
I have a kenmore series 70 dryer (model # 78702894) gas dryer that is running but no heat. How safe is it for me to disconnect the gas line so I can remove the rear panel?
I am having a similar problem (I get heat for about 7 minutes then it stops heating) and just removed the back housing.  I did not have to disconnect the gas line to do this.  Just removed several screws. If your model is constructed differently and the gas line has to be disconnected, make sure you turn the gas off at the shut off switch back at the gas pipe.
Reading on your issue suggests to start by cleaning out all vent hoses to clear any lint obstructions.  I would start there and see if things improved then proceed to removing the back housing to get at the stuff in there.
Jun 25, 2009 | Kenmore Dryers
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Hotpoint aquarius vtd20 not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fjj
Feb 15, 2009 | Maytag SDG4606A Gas Dryer
Maytag performa dryer doesn't fully heat
A couple of suggestions. STOP, be sure the gas it turned off before disconnecting the line. Move it to an open area and check all venting. A good cleaning makes a huge difference. I believe your problem to be the heating coil is on it's way out, "works sometime". Write down the Make, Model, Seriel Number & Year of MFG...someone may ask for it..Check Your local appliance store for price & availablity Easy to replace on most model dryers.
When reattaching the gas line, be safe not to overtighten the coupler. A safe test for leaks is NOT a match... a drop or two of dishsoap around the fittings will bubble if it is not sealed. Good Luck
Jan 02, 2009 | Maytag Performa PAV3200
Whirlpool LER4634J Electric Dryer Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
