Question about Dryers
Tumbler quit moving - Dryers
  • 986 Answers
Usually this means the belt is broken,the belt may have just been old and worn out and it was time to replace it,or perhaps the wheels locked up or the idler and caused the belt to break. Look around for stiff wheels, bad bearings, glides and idlers. Its a good idea to oil the rollers with some temp resistant oil such as zoom oil. Dont use WD40 as this stuff is highly flammable and may cause a fire.
Posted on Sep 12, 2009
Thunder tumbler
My Thunder tumbler works perfectly every day, until now, one of the wheels won't seem to move I looked inside and I saw a Lego brick was in there. There's in opening in the car which is where the peice is. So when I try to make it move only one other wheel moves. HELP ME!!!!!
Dec 26, 2012 | RC Thunder Tumbler Rc Car
Need instructions for rock tumbler
Directions for the NatGeo tumbler are apparently non-existent online. However, I did find the video below to be quite useful. It has some general tips that work with any brand of tumbler. I hope this helps out!
http://www.youtube.com/watch?v=dAi7qH_SJzw
May 15, 2011 | National Geographic Toys
I placed the key in the keyhole but it wouldn't move, and is a bit stubborn. I t couldn't turn on the key..?
if your talking about the ignition then the tumblers in the ignition key switch are probably worn out and it needs replacing as you say it gets stubborn.or the key that you use is so worn that it doesn`t move the tumblers far enough to allow the key to turn,if you have a second key then try it as it may work.if you have a key chain with alot on it the weight can wear the tumblers out.
Apr 21, 2011 | Toyota FJ Cruiser Cars & Trucks
Please Help,how do i change Lock and Tumbler on 1996 Chevy Tahoe
most locks can be re move by taking off the steering wheel and pressure plate behind it, and back out a bolt that keeps the tumbler from sliding out.
Aug 13, 2009 | 1995 GMC Sierra C1500
Tumbler wont spin during spin cycle
Have the motor checked. It may stuck up and needs rewind.
Jul 22, 2009 | Washing Machines
Im replacing a tumbler on my '85 silverado i got the steering wheel off but how do i remove all the other junk to get to the tumbler?
You need to remove the small metal ring that retains the lock mechanism, then remove the turn signal switch (3 bolts, move it up or down to access 2 of them). You will then see a torx bolt that retains your tumbler.
May 25, 2009 | 1986 Chevrolet C1500
Tumbler will not move--need to replace belt
Remove back panel and top of dryer. Than you will have access to the belt.
May 06, 2009 | Dryers
2000 Honda CBR 929rr
The problem is in the ignition switch, although NOT an electrical issue. You will need to remove the ignition and take out the tumbler that the keys rides in. On the back side of the tumbler, there is a white tab that is moved by an arm that slides a pin up and down which locks the steering. Dont be intimidated by this repair. I was when I did it, but was actually quite easy. Just take you time and take pics to look back on as reference.
Mar 07, 2009 | 2000 Honda CBR 929 RR Fireblade
I have lost my instructions to unlock this TARGUS PA400C DEFCON 1 AUDIBLE NOTEBOOK ALARM (PA400C) Do you know where I can find what the default code is?
this may help
Due to the nature of security devices, there is no "magic unlock" code for the Defcon device. To recover a lost combination:
·Set the tumblers to the last known combination.
·While applying pressure to the red release button, rotate the tumblers up one digit and then down one digit on each of the individual tumblers.
·For Example: If your last know combination was 565
1.Set the tumblers to 565
2.Hold the red release button in and rotate the 1st tumbler to 6 so that the combination is now set to 665 (If this is the set combination the red release button will move in)
3.Hold the red release button in and rotate the 1st tumbler to 4 so that the combination is now set to 465
4.If not found move onto the 2nd tumbler and repeat step 1-3
5.If not found move onto the 3rd tumbler and repeat step 1-3
Dec 30, 2008 | Bennett Marine GARMIN StreetPilot...
Dryers Logo
Top Dryers Experts
