Question about Heavy Machinery
How do I replace the pull cord on a briggs and stratoon 1450 series snowblower? The are rivets which I've screwed out, but am having difficulty putting things back together
  • 389 Answers
Since you have already removed the rivets, just go to the numbered portion of the instructions below and follow them to replace the rope.
To put the recoil assembly back on the blower housing, you will need to obtain a pop rivet tool and rivets or or 4 very short machine screws with lock washers and nuts and insert them from inside the blower housing so the flywheel doesn't hit the ends, and tighten them securely
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this.
Posted on Sep 22, 2009
How do I access the pull cord on an Ariens 911072 to replace it?
If housing has screws you take the screws out and take the housing off but if the housing has rivets you take a small drill bit and a cordless or electric drill and drill the rivets out being careful not to make the rivet holes any bigger. Take the housing off and replace the cord then get some same size rivets and a rivet gun and replace the housing riveting it back on. Make sure the housing goes back on the same way it came out.
Sep 25, 2014 | Garden
Replace broken pull cord
the way i done this was drilling out the rivets,replacing the cord and putting new rivets back in.if you dont have new rivets or the tool to put them in with you can use self tapping screws instead. i hope this helps you out?
Feb 19, 2014 | Garden
Pull cord on john deere 190cc 6.75 hp
The housing might be riveted to the engine housing and might need to come off together. Hope this helps!
Jun 09, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
How to replace the broken pull rope
The link below will go over the process of replacing the rope on a briggs mower (process will be similar to your engine for basic idea)
http://www.youtube.com/watch?v=iczCZaRiR0Q
If your starter is bolted to the fan cover it will be easy to remove the rewind and install the rope. If rewind is rivited to fan cover, pull off the fan cover or cut the rivets and then install new rivits (not enough space to use nut with bolt to hold rewind due to close proximity of flywheel). Post agan if you have other questions. Dont worry, easy repair.
Aug 11, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
Trying to replace the pull cord on a toro m#20028 , looks like the bracket holding the cord compartment is riveted down , do u need to drill out the rivets, Briggs & Straton
Yes, its most likely spot-welded, that's not mean to be taken apart there. You have to remove the larger cover that includes the part that is spot-welded on. But first you will probably have to remove some large plastic parts. Just hunt for the screws, there will be several. Some might be hidden under labels. Good luck, Al K
Jul 05, 2011 | Toro Power Lawn Mower
Have to change pull cord but rivits holding down cover am i to drill these out if so stupid design.
If this is a Briggs and stratton then you have to take the engine cover off which is held on by 4 bolts and replace rope. unless you have a rivet gun to replace the rivets you drill out
May 15, 2011 | Cub Cadet Garden
Pull cord broken. After removing red hood and
You don't need to remove the rivets. There should be two metal tabs that bend over the nylon retractor, or it'll have a screw in the middle of the retractor pulley inside the cover. you bend those up a little, or remove the screw, remove the retractor, be careful, because that spring can be fun if it gets away from you, take the old rope out, put the retractor back in place, wind it back as far as you can, feed the rope in, tie the knot, and let it draw the rope in. Put everything back like you found it, and your pull rope if fixed.
Mar 11, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Ho do I replace the pull cord on my snowblower? I've removed the housing, removintg the 4 rivets, replaced the cord,however the tension on the cord is not taut. any suggestions? Thanks Ed
take the rope out with the starter on the table turn counter clock wise about 6 to 7 turns. lining up the holes, stick a screw drive throw the holes to hold. feed the rope throw tie off pull the screw driver out let the starter pull the rope in tie to handle.
Oct 13, 2009 | Briggs & Stratton Heavy Machinery
Heavy Machinery Logo
748 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
