Question about HP Pavilion ZD7140US Notebook
How to reset the motherboard for a HP zd7140us ? I just replaced the heatsink and it worked fine for a week. but now it doesn't turn on, What it could be wrong ? please help.
  • 3,153 Answers
I don't think resetting the BIOS will have the effect you are looking for. Many notebooks hold bios setting differently to a regular PC so removing the bios battery may not work as was suggested. sometimes it requires special procedures and or knowledge to do this with some brands of laptop.
I would suspect that when you cleaned the heat-sink on your CPU you may have accidental forgotten to put new thermal compound on
Whenever a cooler / heat-sink is removed new compound must be put on tho help spread and dissipate heat. Without this there is a chance that the CPU and motherboard could be damaged.
It will do this when it senses that the fan is not working properly or that maybe a setting for the fan is incorrect
First off. If you changed anything using any motherboard / bios utility then change it back or reset defaults.
When you have done that check that the cooling fan / heat-sink for the CPU is secure to the CPU itself (don't remove unless it is loose)
Also check that the fan spins freely.
If it doesn't or feels loose then replace the cooler
Check your manual for the exact instructions but you should remove the cooler completely
DO NOT REMOVE THE CPU
Now with nothing more than isopropynol and cotton bud sticks or another alcohol based cleaner remove the old thermal grease / sticker from the top of the CPU (make sure it is clean)
Do the same with the underside of the cooler.
While the cooler is off it may be worth giving it a good 8low job
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan and you did not pop the CPU or motherboard you should now be back in business.
Posted on Sep 13, 2009
Look on the motherboard, you'll see a battery. take it out for about 30 second
Posted on Sep 12, 2009
What processors will are compatible with an hp 3396 motherboard
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source: http://browser.primatelabs.com/geekbench2/1112660)
Popular CPUs for this board are:
  1. Intel Core i5-3570
  2. Intel Core i7-377
(Source: http://openbenchmarking.org/linux/motherboard/HP/HP%203396)
Feb 25, 2015 | HP 339661-001 HP PCIx Cage DL760 G2 Mfr...
My hp compaq start misbehaving this morning when i boot up the system, it works fine. immediately i try playing around with windows or opening any high resolution programme, the CPU seems to behave like a...
Try downloading the latest video driver. it could just be a faulty driver file. Make sure the heatsink is clamped to the CPU correctly. this is much more important than having thermal paste on it. If someone has removed the heatsink, they may not have replaced it correctly
Sep 18, 2013 | HP Computers & Internet
Processor keeps failing
Have you made sure that it cooled properly? That could be one of the problems, as well as some dust between the motherboard and the processor
Jan 05, 2013 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My pc turns on but no beep or mouse or keyboard light flicker..fan works and cd opens and closes. resetted ram ,use another power supply still same result.. for an a6000 hp
This sounds like a problem I have just had with one of my PC's.
Try clearing the BIOS using the jumper on the motherboard, if that doesn't work (which it didn't in mine) then you may need to replace the motherboard (which I did).
Jun 06, 2012 | HP Pavilion a6000n (882780985018) PC...
I have a zd 7140us from HP my keyboard is messed up. When I press certain keys it opens other thngs. For example: if I press key "w" key "8" or ""u" the window...
if the keyboard is fine and you checked on other computer then it shows that the application you are working has gone corrupt, try to re-install OS and application software.
Also try to check with USB/External Keyboard..
Nov 24, 2010 | HP Pavilion ZD7140US Notebook
How do I replace the processor on an hp pavilion zd7140us laptop?
all you have to do is google your problem and you will have your answer just like that. good luck
Jun 16, 2010 | HP Pavilion ZD7140US Notebook
Continuously beeping and rebooting
Have you tried resetting the c mos?
Take out the memory sticks,reset c mos,put memory back in.
Also is the memory in the proper channel or slots on the motherboard?
Apr 23, 2010 | HP Pavilion a1110n (PX743AA) PC Desktop
Hi, I have an HP Pavilion a367c and the CPU fan is making a lot of noise. The noise comes and goes but "go" periods have been getting shorter :( . I think the bearings are dying. It looks like a typical...
I was going to say dust is whats causing it but then i relized you have opened your computer. So nevermind that.
The fan speed is controlled by the motherboard. The Pentium 4 processor tells your motherboard how hot it is. so then the motherboard turns up the fan faster. Thats why its louder when the CPU is doing alot and is quieter when its doing nothing. You can try replacing the fan yourself but i would recommend just getting a whole new heatsink.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010110574+1371026032&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&Subcategory=574&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
they are cheap! I would recommend the thermaltake one.
Mar 13, 2010 | HP Computers & Internet
My hp pavilion a1330n computer freezes on the HP
the dreaded Blue-Screen of death.
Usually caused by:- Ram Failure ( memory Modules )
CPU Failure ( Processor Failure )
Hard-Disk faulty, not spinning et,c.
Cmos battery fault.
Missing/deleted/corrupted operating System files.
Possible Solutions:- remove cmos battery, from Motherboard for 10 seconds and replace. ( eliminates cmos/bios errors )
remove 1 stick of Memory ( Ram ) and test individually ( eliminates 1 or More Faulty sticks Of memory Or Slots )
remove, CPU Fan/heatsink, remove CPU and re-seat, re-grease with Artic-Silver or similar ( thermal-Compound ) replace heatsink/Fan. test.
Hope this points you towards a Sucessful repair.
Mike @ Compurepair. No-Links No-Nonsense Just Good Practical Advise :-)
Nov 04, 2009 | HP Pavilion Media Center a1330n - AMD...
HP Pavilion ZD7140US Notebook Logo
256 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
