Question about Samsung SyncMaster T240HD 24" TFT LCD Monitor
LCD TV smells like plastic burning--dangerous?
Samsung 26'' LCD TV smells like plastic burning. Did this when new then stopped and 6 mos later is doing it again. What is this? Is it dangerous? Don't see any answers on Samsung Help info; just that it happens. My spouse is blind (listens to TV) and if this is going to catch on fire, I need to know. Thanks. jcarlisle-sd
otacon
  • 1944 Answers
SOURCE: Can I use a memory card SD 2Gb in a camera Samsung Digimax S500 ?
Yes, you can use a 2 GB SD card in your camera.
Posted on Feb 27, 2008
Ajkill
  • 2035 Answers
SOURCE: Samsung 26" LCD TV
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Posted on Jul 17, 2008
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 10 Answers
SOURCE: panel lcd broken samsung ls 26tddsuv/en
I recommend you buy a new monitor, since just fixing the panel would be more costly then buying a brand new monitor. Check out www.newegg.com or www.tigerdirect.com for some good deals on new monitors.
Posted on Jan 15, 2012
SD Tech
  • 14553 Answers
SOURCE: burning smell after i replaced lamp
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
Posted on Apr 04, 2012
Metz CT-4 flash gun overheated on the shaft the plastic casing overheated and melted the plastic on the handle grip I opened it up and noticed the wires inside were completely Melted.
Unfortunately, from your description, the flash is completely done for - while a repair may be possible, I doubt if it would be economically worthwhile. Replacement is probably the only answer.
What may be more important is to find out why this occurred - is it down to the charger, the batteries or an internal problem with the flash ? Were the batteries those supplied by Metz, or a different make ? If they were Metz ones, then maybe you should inform the manufacturers, to help others avoid this problem, and you might get a replacement flash if it is a manufacturing problem.
Jan 13, 2016 | Metz Cameras
Weird smell coming from my samsung LN32D403E2DXZA LCD 403 Series TV
Sounds like an electrical burn from a circuit that is almost touching or is touching another circuit. Or it is an exposed insulated power supply wire that is uncovered and arcing to earth itself on the plastic casing. In any instance I recommend you call the store from which you bought it and tell them about it. They should replace it no question. Unless it is past it's warranty. It could start a fire, so please unplug it from the power supply before you go to bed.
Aug 10, 2012 | Samsung Televison & Video
Burning smell after i replaced lamp
Apr 04, 2012 | Samsung HLP6163W 61" Rear Projection...
New lg tv plastic burning smell
I would contact the store you purchased it from,,,explain the issue and go from there...
Sep 20, 2017 | LG 42LG50 42 in. LCD HDTV
We just installed our 65' tv and it smell like burnt plastic, is that dangerous? what is it
Keep an eye on it, if that is what I think it is. TV will stop working and you will have continuously flashing power light. Call Sharp and schedule a service call.
Dec 05, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Sep 14, 2009 | Samsung LNT2642H 26 in. LCD Television
Smell coming from TV
dear,
yes it can be due to new set. the components are new and have just started working initially that's why they cause smell. if your set is working fine then leave it like that and use it. if it remains after few days or increasing than before then u have to notice it in details otherwise no problem
regards,
Feb 08, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Samsung SyncMaster T240HD 24" TFT LCD Monitor Logo
751 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
