Question about Fisher and Paykel GWL11 Top Load Washer
Hello, This is the F&P Kelvinator GW 508 5.5kg Smartdrive Washing machine. Could this problem relate to the two sensors at the front of the machine under the lid. When I push START/PAUSE nothing happens. I have tried all other tests, & checked everything possible that could cause the machine to not start. That is:- checked the water valves, circuit board, etc.etc. the list of things I have tried goes on & on but nothing works. Could it be the main motor? The sensor that I refer to has slightly perished & so thats why I have asked the question. Regards. Graeme Fordham.
  • Sonia Fordham
    Sonia Fordham Sep 12, 2009
    The switch that your refering to, would it be the tiny switch on the circuit board, or is it
    within another area of the machine?
  • Sonia Fordham
    This is helpful but I still need to narrow the problem down to just the one option!
  • 11,896 Answers
This sounds like more of a switch problem. It very well could be the motor. You can check power to motor with a voltmeter. If you are getting power to motor, than motor may be bad or selector switch is bad. Also a lid switch will prevent operation of the machine as well. You can test this with an ohmmeter.
Copy and Paste this link in your address bar for some little more info and feel free to ask any quesions you may have:
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Posted on Sep 12, 2009
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
Elba by f & p wa65tm leds 3,6 &8 flashing
That is fault code 41
41. (00101001) Temperature Sensor Fault (Thermistor)
The temperature sensor is measuring temperatures above 110oC. The fault is probably
due to a short circuit in the sensor line. This fault is only applicable in the GW models.
Primary Source: Thermistor.
Action: 1) Check the connection from the thermistor the Motor Control
Module
2) Check the resistance of the thermistor. It should read 12.5k ohms
at 20oC. Replace if faulty.
3) Replace the Motor Control Module.
Jul 10, 2012 | Fisher and Paykel Washing Machines
How do I adjust the clutch on an ELBA Model WA50T54W1 top loader washing machine ?
Hi.
Unfortunately the service documentation for Elba is not available. Although the machine has been built by F&P and although is similar to a Fisher & Paykel Smartdrive there are some small difference. The clutch system may be similar to the smartdrive. I have uploaded the service manuals for two smart drive models below, see if that can help. Check section about disassembly.
F&P top load smartdrive smI.zip
Regards.
Ginko
Sep 05, 2011 | Washing Machines
Hi, I have a smartdrive 053 and the water is not draining. It fills and agitates fine but will not drain. When on a draining cycle I can hear a faint electrical hum. I tried turning it off and on again, at...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Washing Machines
I have a smartdrive there is no power to the board
hello mam please check the mains cord and the loose connections inside the machine.
Oct 04, 2009 | Washing Machines
Have a Fisher abd Paykel smartdrive excellance 7.5 all the lights workwill fill wiht water but will not spin by openeing ancl closing the lid you get 1/2 sec try to spin then nothing all you hear is a low...
fisher and paykel 6.5 excellence kelvinator washing machine,lights up,no water,checked hoses to the tap .water comes to the machine ,fill plastic reserve. no water goes in the tumbler.,? .any suggestions.thanks
Aug 15, 2009 | Fisher and Paykel IWL12 Top Load Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher and Paykel GWL11 Top Load Washer Logo
18 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
