Question about Smartpool Nitro Robotic Cleaner and Caddy
I have a nitro model NCXX. It moves back and forth about one foot
4 Suggested Answers
SOURCE: My robo kleen is brand
Sounds like water in the motor . had the same problem and after drying out it worked for a week then the same problem
Posted on Aug 06, 2011
jharwell668
  • 640 Answers
SOURCE: robo-kleen just moves back and
There could be several problems with this pool cleaner that cause it to move back and forth. First, check the impeller to make sure that its not jammed. Take the top grill off by removing the 2 screws from the top. Remove the debris. Replace the top grill and tighten the 2 screws. Next, check your front and rear wheels for any obstruction that could cause lack of movement. You might also need to remove the limit screw from the wheels for greater movement abilities.
Posted on Apr 20, 2011
john224
  • 1378 Answers
SOURCE: I have notro NCXX model and it stopped moving
Thank you for posting your question here on Fixya.com.
It is not recommended you go past the basic troubleshooting since further testing requires breaking open the seals on the cords and motors. Smartpool, the manufacturer, can give you access to their network of service centers by calling 1-888-560-POOL or try their web-based locator at: http://www.smartpool.com/LOCATE/ServiceCenterLocator/tabid/79/Default.aspx
If your unit is still covered under warranty breaking open electrical connections can void the coverage so please consider if it is worth pursuing the repair yourself carefully before proceeding.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 12, 2011
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
I started to sew and the needle does not move and just stitches in place.
does the plate under the presser foot move back and forth that is what moves the material some drop down when in certain modes . like darning or freehand quilting as I see no make I can not look your up anywhere .
Jul 21, 2015 | Sewing Machines
Fabric not feeding on singer model 750
check that the feed button or lever is in the correct position
If it is in the centre position then the feeding foot doesn't know to go forward (normal ) or reverse
If electronic controlled the maybe a service is called for.
Mar 29, 2015 | Singer Sewing Machines
White sewing machine 1866 the foot moves back and forth as I sew.
Did you tighten the screw holding the shank to the presser foot bar?
Aug 10, 2013 | Sewing Machines
I have notro NCXX model and it stopped moving forward or climbing walls
John
Sep 10, 2011 | Smartpool Nitro Robotic Cleaner and Caddy
My robo kleen is brand new and from day one, it just rocks back and forth. It moves forward about 1 foot and then back about 1 foot.
Aug 05, 2011 | Smartpool Dolphin Robo - Kleen Above...
My Nitro Wall climber only cleans a small area back and forth for the entire 3 hour cycle. It litterally rocks back and forth in 1-2 second motion spurts. The drive wheel in the back seems to be working,...
The pump motor is responsible for the programming of the unit and it is failing. You will need a new pump motor installed to correct the issue. For information about sending the unit in for repair you can try our site at www.arrowpools.net or the manufacturer at www.smartpool.com.
John
Aug 19, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
Feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Jun 27, 2009 | Kenmore Sewing Machines
Cant get it out of park how do get it out to move the car
move the steering wheel back and forth if it is locked that is the problem and you will have to move it back and forth while turning the key if not the ignition switch will need replacing
Sep 11, 2008 | 2003 Mazda Mazda6
Smartpool Nitro Robotic Cleaner and Caddy Logo
296 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
