Question about Refrigerators
My Kenmore ice maker is making ice but it will not, or can not, dump the load. The tray will rotate pushing the cubes verticle and then stop.
  • rvautard Sep 14, 2009
    Thank you for this input.
    The service sheet is too small to read. I printed it off, but can not enlarge it.
  • rvautard Sep 17, 2009
    GREAT INFO - THANKS.
    Now I know why the repair guys/gals get the big bucks. After all the troubleshooting, and defrosting, I ordered a new ice maker. After 6 days of being "stuck" the ice marker started to work. Go figure!!
    Thanks again - I printed off your info for the next go around.
  • Refrigerators Master
  • 19,396 Answers
as you may have been explained the ice maker uses an evaporation system to release cubes.
The evap system consists of an heating coil , a small fan, and a temp sensor. when cubes are placed upside down, the heating coil will start warming up, melting the surface of the cubes and releasing them.
In your case the problem may have been caused by a bad connector or a wiring problem, since the icemaker restarted working on its own.
Please let us know if you need further help, and please do not forget to leave us feedback later.
Many thanks.
G.
Posted on Sep 17, 2009
  • 612 Answers
You will need a new main gear. It is located behind the front cap of the ice maker. If it stops like your saying, the gear has a couple teeth missing from the main gear. If you will go to www.partselect.com and look at part # PS380968 This is the part you will need.
Please rate solution
Posted on Sep 14, 2009
  • 1 more comment
  • James Hilton
    James Hilton Sep 15, 2009
    If you pull the front cap off the ice maker, you will see a large gear and a small one. The large gear is what I think you will find has a few teeth gone. You can use a screw driver, place it in the screw in the middle of the large gear. Turn clockwise, it will be hard and only turn it like you holding pressure on it to turn. It will then start turning by it's self. This is what is called cheating the ice maker. It makes it advance. This should cycle the ice maker. After it dumps, fills and refreezes for about 30 mins. Cheat it again to start harvest mode. See if it will stop in the same place again.
  • James Hilton
    I meant to add. If you have a new model, it will not have this gear so that you can get to it. In this case, you will have to replace the module (Ice maker head)
  • James Hilton
    James Hilton Sep 16, 2009
    Where you able to locate the main gear? If not, it should be one of the newer models that has a gray module when you remove the cover. If so, you will have to replace the module.
  • 854 Answers
Maybe this will help
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Kenmore Side by Side Refrigerator
Ice maker not working has frozen ice inside tray and had cubes on top it's just no longer moving
remove tray, ice may be frozen around auger or gear that spins auger, dump all ice and start over making ice. also, wile tray is out hi dispense switch and see if grer spiindle rotates, if not ur motor has gone bad
May 22, 2010 | Kenmore 53603 / 53606 Stainless Steel Side...
I have the samsung rs2577sl. the ice maker cube
Your model has the twist tray style icemaker. The part number for you front section that contains the motor assembly is DA97-00258E Ice Maker Assembly. You can try by taking it out and seeing if the tray will return to the home position but stopping there make me question if the thermal fuse in wiring harness may have blown. We may need to test that wire also to see if the thermal fuse is still good, I will leave you some of the links and ready to help when you need me, Thanks, Sea Breeze
Apr 21, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Mod. GS6NBEXRS01 not dumping ice. there is ice in the ice-maker. the dispenser for the water working ok.
take the bin out and check for a jammed ice cube in the ice cube making mechanism. Many times they have a rotating finger that gets stuck on a cube that does not drop entirely. Hope this helps
Jul 13, 2009 | Kenmore 74252 / 74254 / 74259 Top Freezer...
Ice cubes stick to tray and motor can not push them out!
what it is the heater that goes on the ice maker tray is not working properly. Possibly the contact are not making a good cotact or not coming on correctly.
Dec 23, 2008 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Ice maker
The is a small heater in the boottom of your ice maker that is most likely not working. The heater comes on when the ice reaches a frozen state to allow the ice to melt just enough that the rotating arm can push the cubes out and into the tray.
Unfortunately, it will most likely cost more to have a technician fix the existing ice maker than it would to just have anew one installed.
I would opt for the new ice maker.
Jun 04, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
