Question about LG Incite Cell Phone
I downloaded a ringtone for my LG Incite but I can't install it. Its not coming up on the lists of ringtones... pls help... Also if I get it through bluetooh its the same problem
LG CT810 has a size limitation of 300K for ringtone... you must have mp3 file that over the limited size, so it won't show up.
Reduce the size by lower the mp3 sound quanlity and then you are good to go. Simply save it in "My Documents" folder and it will show.
Posted on Oct 23, 2009
What is the 16-digit Subsidy Unlock Code for LG Incite?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 26, 2012 | LG Incite Cell Phone
My LG mobile keeps saying maximum number of applications reached each time i try and send a text HELP
That means there isn't much memory left. You will have to delete some applications:
The uninstall processes on LG Incite mobile phone are not complicated, three ways you can choose below according to situation/setup. LG Phone Problem and solution
1. Uninstall Apps Using ActiveSync LG-Incite info
For Windows XP and below users will want to use the ActiveSync program. You can download ActiveSync 4.5 here.
Once downloaded and installed on your desktop ActiveSync uninstalls are one of the easiest ways to remove unwanted programs, simply follow the directions below:
  1. Connect your LG Incite to ActiveSync
  2. Click on the "Tools" option
  3. Click Add/Remove Programs
  4. At this point you'll see a screen that lists all of your devices programs, each program will have a checkbox to the left of the programs name and all of your programs will have a checkmark located next to their names.
  5. Take out the checkmark in each program box you'd like to uninstall.
  6. Click "OK"
It's really that simple, your LG Incite will take a moment to uninstall the unwanted Windows Mobile Apps you chose and then you're done.
2. Uninstall Apps Using Windows Mobile Device Center
If you're a Windows Vista desktop user there's no reason to download ActiveSync, partly because it won't work, but more importantly because Windows Vista comes standard with the Windows Mobile Device Center, a device to desktop sync application that functions in much the same way as ActiveSync 4.5.
Uninstalling Apps with Windows Mobile Device Center is a simple process if you follow the quick steps below:
  1. Connect your LG Incite via USB to your desktop to launch the application.
  2. Click on the "Programs And Services" option
  3. Click the "More" option, You will now see a program box similar to the one found with ActiveSync 4.5.
  4. Each program will have a box with a checkmark, find the programs you'd like to uninstall and uncheck that box.
  5. Click "OK"
The unchecked programs will now uninstall from your device, its really that simple.
3. Uninstall Programs Directly From Your Windows Mobile Device.
You don't have to use a computer to delete programs from your LG Incite, if you're on the go uninstalling apps directly from your system once again involves only a few quick steps.
  1. Go to your "Start" button
  2. Go to "Settings"
  3. You'll see a "System" tab, click on that tab.
  4. Then go to "Remove Programs"
  5. Choose the Application you want to remove and highlight it.
  6. Click "Remove"
Your LG Incite will now remove the highlighted application.
Personally I usually use my computer for deleting apps just in case anything goes wrong during the uninstall process, however i've rarely heard of people running into Windows Mobile uninstall issues when doing so from their devices.
Conclusion
The 3 uninstall options listed above are the easiest ways to uninstall apps from your Windows Mobile based Pocket PC and Smartphone devices.
If these steps don't work your best bet may be to use the "Clear Storage" option on your Windows Mobile device and start your device with the standard fresh install, but hopefully it doesn't come to that."
Feb 28, 2011 | Cell Phones
LG INCITE TOUCH SCREEN PROBLEMS
if you take out your battery, then put the battery back in it should unfreeeze.
Apr 01, 2010 | LG Incite Cell Phone
How to replace lg incite digitizer
http://www.lg-incite.com/lg-incite-tutorials/how-to-replace-digitizer-on-lg-incite/msg40310/#msg40310
Complete instructions on how to tear down the Incite to replace the digitizer. Be aware that most if not all replacement digitizers do not include the adhesive, which is a separate part number. Most people can reuse the existing adhesive, but if not, scrapbook adhesive works.
Jan 16, 2010 | LG FOR INCITE CT810 AT&T CLEAR LCD SCREEN...
I cannot get downloaded ringtones to work on my lg incite.
Go to the website phonezoo.com and sign up. It is absolutely free and there is no fee at any time. This website has thousands of ring tones and enables you to take music from iTunes or a CD and convert them into 30 second ring tones.
Sep 16, 2009 | LG Incite Cell Phone
Lg Incite
Hi, USB driver and manual of you phone can be found in below link.
http://www.att-phones.org/att-lg-cu920-driver-download.html
I hope this helps.
kind regards.
Jul 16, 2009 | LG Incite Cell Phone
I have a LG incite
Okay -- you haven't posted anything else aside from "I have a LG incite" So, is there something wrong with it? how can I help?
Jul 10, 2009 | LG Incite Cell Phone
Ok i have a ringtone on and LG Incite and i dont know how to set it as my ringtone, so when someone calls me that rintone is playing.
First of all, the ringtone can only be a maximum of 300 KB which is about 20 seconds long. If the ringtone is larger than this, than it can't be used as a ringtone. After having the ringtone on the phone, you can go to my pictures and videos, and then click on the tab in the upper left corner and go to my documents and my ringtones. This should be where the ringtones are stored on the phone. You can find the ringtone on the phone and copy and paste it to this spot, or you can simply drag and drop the ringtone from your computer to this location if it is hooked up via USB. (but, the phone will not work on the computer until the installation cd is used that came with the phone.
Jun 07, 2009 | LG Incite Cell Phone
Try to download ringtones and it pops up http error forbidden
Well it's because DRM. The easiest way is tranfer ringtones through pc. as it's an wm6.1 device various formats can be used (wav,.mp3 etc).
Apr 22, 2009 | LG Incite Cell Phone
How to load softwaree on lg incite mobile
Download the file install_fp6_ppcax_en.exe from the website http://download.macromedia.com onto your LG Incite and install it.
Cheers,
Kiran.
Apr 20, 2009 | LG Incite Cell Phone
LG Incite  Cell Phone Logo
291 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
