Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Got audio and text, but no picture. I adjusted my set after digital switchover when some of my channel signals were poor and I have obviously pressed some kind of picture mute. Please help!
  • 458 Answers
Try setup" cc " off:
Posted on Sep 13, 2009
Testimonial: "My tv is a Toshiba 37 inch Regza LCD. I have been through the set up options and cannot find 'cc' off. Can you elaborate please."
  • tvservice306
    tvservice306 Sep 14, 2009
    need toshba tv model ...
Poor picture quality on alba LCD TV after recent digital switchover.
Digital TV uses less airspace than analogue TV, so after the digital switchover there'll also be more room for services such as high-speed mobile broadband and high-definition television (HD TV).
Sep 16, 2012 | Televison & Video
Hitachi TV - no signal on DTV since switchover
Hi It sounds like you need to re-tune your DVB-Tuner on your TV, NOT the old analogue one, it'll be in settings or setup, or installation and use the "First Time Install" option, because it clears all old channels and loads all fresh new ones! hope this helps!
Dec 06, 2009 | Televison & Video
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Samsung LE32R7 will not retune since switchover
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Unable to tune in the digital programs after digital switchover . there is no analogue signal. when i click on menu it allows me to select all but 2 of the options and tuning is one of the options that it...
If you were unable to tune in digital before the switchover then most likely your digital reception is poor. Unlike analog signals you will not see anything on screen until it can lock in. You may have to repoint your TV antenna or check what size of antenna you need at antennaweb.org
Sep 10, 2009 | Televison & Video
Sony digital tv KD 32DX40U wont pick up digital signal
The tv is a 2k model - I have the same one, digital is now 8k so it won't work digitally anymore.
2K Equipment
  • All 2K-only products will stop working with the introduction of the 8K transmission mode at switchover.
  • 2K-only set-top boxes cannot be upgraded, but 2K-only IDTVs can be updated by adding a current set-top box or digital TV recorder.
  • A full list of affected models is on the Digital UK website at www.digitaluk.co.uk/2kequipment.
Jul 08, 2009 | Sony Televison & Video
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
No BBC 1 or 2 after digital switchover.
I have the same box and re-tuned mine with the same results as you.However i discovered that the NEW BBC channels were on the channel guide list starting at channel 800
May 07, 2009 | Televison & Video
Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Mar 26, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Poor quality pictures
You may try to adjust the LCD light.
Do the following:
- Press Menu
- Go to Set up
- Look for LCD
- Try to select any of the options under LCD
Aug 25, 2008 | Samsung Digimax S800 Digital Camera
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
129 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
