Question about Dryers
4 prong dryer cord to 3 prong dryer cord
How to I change out a 4 prong dryer cord to a 3 prong dryer cord. Does the neutral go in the middle.
  • 1 more comment
  • fetjake Jan 03, 2008
    I am trying to switch back to the original 3 prong cord from a 4 prong cord. All of the wires are gold with no color indications to match up to the 3 colors on the dryer. They all just say ten on them what do I do?
  • Anonymous Mar 11, 2008
    which color goes togerther
  • tucker1711 Mar 31, 2008
    3 Prong dryerord to a 4 prong dryer cord
  • 262 Answers
Posted on Dec 11, 2007
Im gonna try this step above.If I blow up then yall know I hooked up somethin wrong.peace out.
Posted on Dec 02, 2009
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
Need to change the power corrd to a 4 prong from the 3 prong but the 3 prong cable isnt color coordinated, how do I hook up the new power cord?
The new cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground.
Jun 24, 2011 | Kenmore 62622 Electric Dryer
I need to switch the power cord from a four prong to a three prong. The three prong that I purchased is a 30 amp. Will it be sufficient? Only one of the strands on the three prong is labeled. The...
30 amp. will work just fine...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
Feb 06, 2011 | Dryers
I need to change the dryer power cord on my Amana NDE6800AYW dryer. The current cord is a 4 prong with four wires that are black, red, green, and white. I need a 3 prong plug and I got a cord a Home...
The two wires on either side of the power cord are your HOT leads. They are the voltage carrying conductors. These two wires will connect to the terminal block on the RED and BLACK wires. The middle wire is NEUTRAL and goes to the WHITE wire at the terminal block. Now...with a 3-wire configuration you will need to connect a grounding strap to the neutral wire and ground it to the grounding lug of the appliance. The following link explains:
The main difference between 3 and 4 wire configuration is how the neutral and ground wires are installed. In a four wire configuration these two are independent of each other. In a 3 wire configuration ground and neutral are connected together.
If you have any questions about this repair, please ask me. I hope this helps you.
Jul 17, 2009 | Amana NDE6800AYW Electric Dryer
I need help in changing the 4 prong to a 3 prong cord
It would be a better and safer idea to change the receptacle from a three prong to a four prong. You would also be in compliance with the electrical code. That being said, here is the info you will need to go either way.
Apr 03, 2009 | Kenmore 84832 Electric Dryer
Changing from 3 prong to 4 prong cord
Mar 19, 2009 | Dryers
Roper Dryer
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Mar 02, 2009 | Roper Dryers
4 prong to 3 prong
Get the 4 prong cord off. Put the 3 prong cord on.
The middle wire(neutral) on the middle post. The other 2 wires are hot wires. Make sure you have the middle wire in the middle and a wire on each side if it. The Green wire is redundant and NA on 3 wire receptacles. Directions should be posted just above the terminal block.
Dec 14, 2008 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryers Logo
1,367 people viewed this question
Top Dryers Experts
