Question about Hitachi 53UDX10B 53" Rear Projection Television
Power up Problem
Can you guide me in the right direction, I have Hitachi TV that turns on automatically after a power failure in the home. Also I am now experiencing an intermittent problem which I believe is associated with the first problem which is that the when I go to turn on the TV the red power indicator light turns on but there is no picture or sound.
    President:
  • 4,402 Answers
I think this is your problem
The convergence board needed to be "rebuilt" (lots of cracked solder) The ICs were shot as were several resistors.
this is how to fix it.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 11, 2007
Hi I think my Hitachi C29-F500DR TV has a fault. At first I thought someone had inadvertantly set the timer but the power indicator is not blinking 10 seconds on, 1 second off. It is blinking 3 shorts ,...
Blinking lights indicated any component failure in the TV .
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If its within warranty Please give to the company.....
OR
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
Good luck..
Jul 27, 2008 | Hitachi Televison & Video
I have had a Hitachi 42" Plasma screen TV for almost 3 years and recently it has had problems. When you turn it on, the TV only stays on for about 10 minutes, and then the screen goes black with the...
The signal from the STU to the Hitachi box is going in the wrong direction.
Is the adaptor that you have switchable? If so, flick the switch in the
other direction and this will fix it. If the adaptor is not switchable get
one that is. Then set the STU output to RGB.
Hope this Helps. -CA
Jul 14, 2008 | Televison & Video
My television just went off! We tried to turn it back on but it wouldnn't come back oh. Finally the button flashed red like it was trying to come on and we heard 2 or 3 words then that was it.then the...
Tries tv unplug,replug it back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If it have the same result.Yes,the power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 03, 2011 | Hitachi P50H401 50 in. Plasma HDTV
NO POWER
Good Day, david375;
There toooooo many things in the TV that could go wrong, so it's hard to determine what wrong. The avg cost is about $550.00 For some one to come to your home and repair it there.
good Luck, big IRISH.
Aug 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi hdtv flat panel tv no soundand no picture
Most of the case horizontal output transister failure cause these type of problems. Additionally flyback transformer failure also leads same problem but it depends upon aging of the tv. Whatever it is it could be fixed by service Technician only.
Jun 24, 2008 | Hitachi Televison & Video
Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
42edt41a
Several runs had bad display panels, but other failures can cause a shutdown condition. There is a fuse in the power supply that must be removed in order to determine the failure by checking voltage at the fuse socket. I suggest you find a local authorized Hitachi servicer to continue. This is not a simple fix.
Oct 27, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 53UDX10B 53" Rear Projection Television Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
