Question about Kd Tools Automatic Transmission Clutch Spring Compressor
I change my clutch on my mitsubishi eclipse but now the gears dont want to go in wen the car is on
  • Lunatic_75 May 11, 2010
    is the clutch working. When its running can you get in gear atall.
2007 Mitsubishi eclipse clutch was slipping but put in new clutch throw out bearing pressure plate had flywheel shaved now I have no gears checked gear oil it's level bleed lines and still no gears
how much was taken off flywheel ? was there a shim between crank and flywheel ? did you make sure spline count on clutch plate matched spline count and diameter on input shaft to transmission
Apr 17, 2015 | 2007 Mitsubishi Eclipse
On my 1997 eclipse ,the engine runs but the trans will not go into any gear.
Is this an automatic or straight drive?
if straight drive will it go into gear not running?
Sep 04, 2008 | Mitsubishi Eclipse Cars & Trucks
2007 Mitsubishi eclipse spider just put in clutch kit now it will not engage I can put it in gear without car on and I can push the car back and forth
Sounds possible you have the friction plate in backwards and there is no clearance. Retrace your steps and check the clutch operating mechanism, then any gear linkage. With the clutch centre plate, the raised part of the spring carrier is usually facing outwards toward the pressure plate fingers.
How i change the clucth of my mitsubishi 1997 gsx eclipse
Try bleeding the slave cylinder first.changing a clutch involvesmore than you can learn on this site. You need a repair manual. I recommend Haynes manual. You can find manuals at any store that will sell you a clutch.
May 31, 2014 | Mitsubishi Cars & Trucks
99 mitsubishi eclipse installed new clutch kit,all gears work except reverse,why wont it get reverse?
the selecter rods are not in the right position you may have turned gearbox drive shaft when locating new clutch sorry your going to have to take selecter mechanism off and by a bit of trial and error reposition until you can select all gears
Mar 18, 2014 | 1999 Mitsubishi Eclipse
It wont start got new bat. no noise wen trying to start
if stick shift check the clutch pedal switch
if automatic try cranking while shifting through the gears
often the shifter linkage is out of adjustment
Sep 06, 2010 | 1995 Mitsubishi Eclipse
Car wont drive in gear
are your cv shafts still in tact? if so then your trannsmission needs to be serviced
Apr 25, 2009 | 1996 Mitsubishi Eclipse
I dont know where to put the oil for the gear box
Brake fluid is the same fluid you put in the clutch master cylinder. Any mechanic will verify this.
Nov 20, 2008 | 2003 Mitsubishi Eclipse Spyder
Kd Tools Automatic Transmission Clutch Spring Compressor Logo
150 people viewed this question
Top Kd Tools Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Kd Tools Air Tool and Compressor Expert? Answer questions, earn points and help others
