Question about Compaq Armada 1750 Notebook
How to disarm administrator? - Compaq Armada 1750 Notebook
  • 4 Answers
Try booting from safe-mode.
Posted on Sep 12, 2009
How do I disarm my security system without the original key
You can ground the factory disarm wire, to permanently disarm the factory security. That wire's location and color is as follows;
Factory Disarm-----Purple/Yellow (-)----- Driver's Kick Panel Black Connector
Feb 07, 2011 | 1993 Jeep Grand Cherokee
Which fuses can I remove to disarm 1994 jeep grand cherokee. Jeep is stuck in security mode and will not start. I bought it used, so no keyless entry. Manually unlocking/locking driver door, passenger...
I don't know about a dedicated fuse but you can try disconnecting the battery for a few minutes then, with the battery still disconnected, turn the ignition key to on, then reconnect the battery. This has been a known way to also disarm the factory security.
If that doesn't work, and if you are handy with vehicle electrical, you can ground the factory disarm wire, to permanently disarm the factory security. It's location and color;
Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector
Feb 06, 2011 | 1994 Jeep Grand Cherokee
The panic alarm sounds
it sounds like one of your door switches is setting off the alarm. Or you hood or trunk switches.
Anti-Theft -Perimeter The perimeter anti-theft system consists of the following:
  • door lock cylinder disarm switches
  • liftgate lock cylinder disarm switch
  • generic electronic module (GEM)
  • door open warning lamp switch
  • pulse stretcher module (wagon only, is located between the rear license plate housing and bracket)
  • keyless entry remote transmitter
  • hood switch/bracket assembly
Principles of Operation
Perimeter Anti-theft
The perimeter anti-theft feature provides an audible and visual alarm when unauthorized access to the vehicle is detected. When an intrusion is detected by any door or liftgate ajar switches, or the hood and trunk tamper switches it sends a ground signal to the GEM. When the GEM receives a signal indicating intrusion into the vehicle, the GEM supplies a ground signal to the horn control relay and the park lamps relay. The relay closes, supplying the power which activates the horn and the park lamps. The pulse stretcher module applies to wagons only. Due to the distance between the liftgate disarm switch and the GEM, the disarm switch signal is not present long enough for the GEM to recognize. The pulse stretcher module receives pulse input when switch is turned to unlock. The pulse stretcher module holds the pulse active for about 60ms so the GEM can recognize the signal and disarm the system. The perimeter anti-theft feature does not arm until 20 seconds elapses after locking the vehicle. The perimeter anti-theft device will disarm only when
  • unlock is pressed on the keyless entry remote transmitter.
  • keyless entry keypad code is entered.
  • door, luggage compartment lid or liftgate lock cylinder is turned to unlock.
  • ignition switch position changes to run or start.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Lock cylinder disarm switches
  • Hood switch
  • Luggage compartment lid switch
  • Loose or corroded connections
  • Generic electronic module (GEM)
  • Circuitry
Door Disarm Switch Removal and Installation
  1. Disconnect the battery ground cable. Refer to Section 414-01 .
  1. Remove the door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the watershield.
  1. Disconnect the latch lever from the door lock cylinder.
    1. Remove the E-clip.
    1. Disconnect the latch lever.
  1. NOTE: The door disarm switch can be installed in more than one position. Before removing the switch from the cylinder it may be necessary to mark the position of the switch in relation to the lock cylinder.
    Remove the door disarm switch.
    • Disconnect disarm switch electrical connector.
  1. NOTE: The door disarm switch can be installed in more than one position. Use the reference marks applied in the removal procedure to index the new door disarm switch to the lock cylinder.
Jan 24, 2011 | 2005 Mercury Sable
I have a crime stoppers remote start/alarm when I use the unlock button it only unlocks the doors, it does not disarm the alarm. How do I disarm the alarm?
You need to hook up the disarm wire also and depend of what car you're working on, it will disarm when you unlock the car.
Jan 13, 2011 | 2-Way Remote Starter
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
How can i disarm the factory security alarm.i have tried the key locks. i have no remote with the car. i didnt know it had an alarm when i bought it . 1995 chrysler cirrus
Here is what I do on my 95 Cirrus I also do not have a keyless remote (well I do but is broke) and after frustation after frustation trying to disarm the factory alarm I find out that by unlocking the passenger front door with the ignition key from the outside will disarm it you may have to try few times before it's disarmed you need to make sure that the blinking red light stops blinking and all of the locks on all 4 door are up or unlocked, this is what I been doing for 3 years now and that's how I disarm the alarm on my car, I hope this helps.
May 15, 2010 | 1995 Chrysler Cirrus
Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Jul 16, 2009 | Vehicle Parts & Accessories
I need to disarm the alarm but i cannot find the swtich under the steering column. please help
There no switch to manually disarm . The ignition key has micro chip on it and that the only one used for disarming (OEM)
Jul 14, 2009 | 2004 Dodge Stratus
How do i disarm an alarm on a 1993 ford explorer without the key remote
THIS IS FROM YOUR OWNERS MANUAL:
Disarming the System
An armed or activated system can be disarmed if you:
n Unlock the doors by entering the unlock code on the keyless
entry keypad.
n Unlock any door or the liftgate with a key.
n Turn ignition to the ON or ACC position.
Nov 03, 2008 | 1993 Ford Explorer Limited
Compaq Armada 1750 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
