Question about Xerox Phaser 6350/YDT Laser Printer
Light print problem phaser 6350
Light print problem phaser 635, swapped everyting...
Xerox black developer fade printing
Try this: http://www.fortwayneprinterrepair.com/wordpress/2014/03/17/xerox-phaser-6500-workcentre-6505-light-print-issues
Apr 25, 2014 | Xerox 6500/N Phaser Laser Printer
Xerox Phaser 6125 prints pink
you cal also try to clean the laserwindow of the Magenta imaging unit
Nov 08, 2012 | Xerox Phaser 6125 Laser Printer
Printer is printing the black color as light grey. Toner is already exchanged.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Jan 11, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Apr 02, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 6350/YDT Laser Printer Logo
184 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
