Yamaha R-V98 Stereo Receiver
My Yamaha R-V98 stereo receiver won't stay turned on for more than a few minutes before it shuts off. There is a "Sleep Timer" function that doesn't seem to have any effect, no matter what I set it to or turn the function off.
If you are running two low of an impedince (sorry i can never spell it right) or anything that runs under 8 ohms, which some speakers depending on the frequency will shut it down,
i have the same receiver and had the same problem,
it ended up for me that my center channel wasnt 8ohms,
the man A and B speakers will run ok at 4 ohms,
but the center channel is really picky,
hope i helped man,
you can contact me @ scottdilbeck@yahoo.com if you are still having problems,
or if that isnt the problem,
ive become familiar with mine inside and out
Posted on Jun 14, 2008
My yamaha stereo receiver powers down with in seconds it wont stay on
there is most likely a short in the amplifier section that needs to go in for service. Try disconnecting all speaker wire from the back of the receiver and power it on that way. If it stays powered on, then you have a shorted speaker or wire. If it still shuts down, then it needs service
Oct 10, 2015 | Yamaha Audio Players & Recorders
Whats wrong with my stereo
How old is your HK receiver? The power supply capacitors can get old and tired, and cause the hum and shutoff. Repair is an option.
May 03, 2015 | Harmon Kardon Harman Kardon AVR1600 50W/CH...
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Yamaha r-v98 turns on and immediately goes off. I haven't changed anything lately. It was playing then went off. Now it will not turn on for more than a few seconds.
Disconnect all speakers at the receiver then turn it back on, if it stays on, post a comment and I can help you troubleshoot further. If it still shuts off, it sufferred a power spike and needs to be serviced. They will replace 5-6 caps and 2 or three other parts, roughly 250 or so. Hope this helps
Aug 21, 2009 | Yamaha RX-395 Receiver
Yamaha R-700 Natural Sound Stereo Receiver won't turn on.
My stereo receiver aiwa MX-NH2000 can not turn on. It has standby.
May 03, 2009 | Yamaha Audio Players & Recorders
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
Won't stay on
If you have the service manual there is a section that shows you how to get the protection mode history with the codes. You can also reset all of the protection from the service menu listed above. Be careful in doing so but have fun if your fed up with it not working.
Apr 06, 2007 | Yamaha HTR-5730 Receiver
Surround sound problems
Try changing your cables
Mar 11, 2007 | Yamaha HTR-5660 Receiver
673 people viewed this question
 Grubhead
Grubhead
