Question about Motorola Mobility ROKR E6 Smartphone
Micro SD card is write protected, but can't seem to reformat it
I'm trying to load files onto a new 8 GB blackberry micro sd card (via an adapter and a Dynex 6 in 1 reader). I've got a MacBook, and when it the icon goes on my desktop, it says "no name." When I click on "more info" it is clear that the disk is read only, and formatted for MS-DOS (FAT 32).
My card reader user guide says that I may need to reformat the card on a pc to be just FAT or FAT 16. But when I try to do that, I'm not given the option to change the format, the only thing in the pull down menu is FAT 32.
Is formatting my problem or is it something else? I'd like to be able to put music, podcasts and photos on my card (since itunes won't sync via Pocket Mac)
(Probably not relavent, but interesting is it says it was created and modified Monday, December 31, 1979. What's that about?)
  • isuteacher Sep 15, 2009
    Thanks. You're right, when I used a pc to try and format the disk, FAT, or FAT 16 was not even an option. So I guess that means I'm stuck with my 2 GB disk? And I can never add anything manually to the disk, because I'm a mac user? That doesn't seem right! All I want to be able to do, is drag songs/podcasts to the disk, because Blackberry doesn't offer software for Macs to do this via a synch tool. :(
    Problem Solver:
  • 16 Answers
You might try formatting it with a windows pc. Sometimes devices have problems with cards formatted by Mac. Even when it is formatted to a FAT file system. On a side note I don't believe that Macs will format to Fat 16 anymore. (Macs use a different file system that windows altogether). You may also check the card to make sure that there isn't a manual read only switch. (It would show a picture of a small lock next to a tiny switch on the card)
Posted on Sep 13, 2009
How to reset the password memory card
Transcend??
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab.
Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
or
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to Step 2.
Affix a small piece of tape or paper to the top half of the gap where the slider should be. Do not permanently affix the paper as of yet. 3
Try the card in your computer, using the USB converter stick.
If the items on the SD card are available, copy them to your computer as a precaution.
If that did not solve the problem, proceed to Step 4. 4
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side.
If you are actually trying to unlock a micro or mini SD card, proceed to Step 5. 5
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card.
Micro and mini cards do not have switches.
Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data.
SD Adapters look very much like SD cards and the switch works the same way.
Nov 26, 2013 | PNY 1GB microSD Memory Card
I've Been Syncing Music Onto My Micro SD Flash Reader With No Problem Until Now. It Keep Saying Can't Create or Copy Certain Files Because The Disk Is Write-Protected and Would Like To Know How To Remove...
On the SD Card adapter housing for a Micro SD card, look along the edges and you will find a small tab. This tab slides back and forth to either lock or unlock the card. It is for write protecting you files.
Feb 25, 2011 | Kingston MicroSD 2GB (2 Gigabyte) Card for...
MicroSD atchment write protect
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
Mar 07, 2010 | Cameras
My PC will not recognize my 2GB Micro SD Card
Does the PC recognize the adapter when you place onto the USB port? If not, try another USB port. It should atleast say it has detected hardware, see if it's finding and installing the drivers correctly.
If it's not the adapter, could you reformat the microsd card? Perhaps, it is corrupted? Is this SDHC or SD (what capacity). Older Blackberries do not support SDHC (I believe this is 4gb or above), perhaps this has something to do with it.
I hope this helps,
Bill
Sep 04, 2009 | SanDisk 2GB microSD Memory Card
What's the biggest micro sd card that fits htc s 620 smartphone?
  • Micro SD Compatible with the following Smartphones:
  •  Blackberry 8800
  •  Blackberry Curve 8300
  •  Blackberry Pearl
  •  Palm Centro
  •  Samsung BLACKJACK
  •  T-Mobile Dash, HTC S621 & HTC S620
  • 4GB Micro SD - Secure Digital Card with SD Adapter
    Hope this helps, if it does please rate accordingly, David
    Mar 18, 2009 | HTC S620 Smartphone
    Does not read from adapter
    then it must be password protected.Delete the password of micro SD from your cell and then try.........it must work........
    Apr 16, 2008 | SanDisk 4GB microSD High Capacity Memory...
    Turn off write protection on a sd micro card
    If you are using it with the SD adaptor, the swith at the side marked lock is not to secure the micro sd card within the adaptor. This is the write protection. If you set this to the 'unlocked' position (up) then you should be able to write files onto it!
    Apr 04, 2008 | Nokia 6288 Cellular Phone
    Unable to read DS micro SD card games
    Have you installed Moonshell onto the micro-SD card? It has to be there to see the games. If you have Moonshell installed, you should be able to navigate to where you stored your files. Your adapter should have come with a CD with Moonshell on it or you can download a newer version on the internet.
    Mar 31, 2008 | Nintendo DS Lite Console
    Cannot load maps onto micro SD card.
    Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
    Feb 17, 2008 | Garmin eTrex Vista GPS Receiver
    Motorola Mobility ROKR E6 Smartphone Logo
    605 people viewed this question
    Top Motorola Mobility Computers & Internet Experts
    David Payne
    David Payne
     Paul Flint
    Paul Flint
    Level 1 Expert
    Tom Chichester
    Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
