Question about Canon C330D Copier
I got e-005 error code, how can reset the error from main board? already replaced fuser web, I know how to get in service, but I don't know what is the next step.
  • 5 more comments
  • LUIS GRANADOS Sep 14, 2009
    you send me the wrong answer, I am not worrking with hp product, I am working with CANON COPIER C250/C330, ERROR CODE E-005, Ineed to know how reset this error code, please send me the right answer.............ACS
    I work in canon copier C250d, I have error code E-005, I need to know how reset this code
    I AM WORKING IN canon copier c250d, I got ERROR CODE EOO5, how can reset this error?
    THIS IS NOT DIGITAL COPIER, THIS IS OLD ANALOG CANON COPIER C250D/C330D, i NEED TO KNOW HOW RESET ERROR CODE E005
    THANKS FOR YOU HELP, BUT I THINK THIS DIRECTIONS ARE FOR DIGITAL CANON COPIER IR-330; I AM WORKING IN OLD ANALOG CANON COPIER C250D/C330, ERROR CODE E005, CAN YOU HELP WITH THIS PROBLEM?
    I am woring in CANON COPIER C250D/C330 ANALOG COPIER, AND IHAVE A ERROR CODE E005; HOW CAN RESET THIS ERROR CODE FROM DISPLAY?
    Thanks for answered my question, but I think the solution you gave is for digital copier IR-330, Iam working in canon C250D/330D Analog copier, is the kind of copier that have to open front door, activate service switch with a paper clip in the little hold located up in your left hand, the display going to mark (1), or (2) or (3) etc... I need to know wich code is, if is 4, 5 or 6 and press the OK KEY located in the left side of the panel, after press OK I am going to get the sub-code 401, or 501, or 601; what I need to know is wich code and wich sub-code are to reset the E005 CODE ......HOPE YOU CAN HELP ME.
  • 313 Answers
Did you go into service mode and clear the error code???? if not that is what you have to do... additional function 2 and 8 same time then additional functions >copier>functions>clear> error> ok you have to clear the web counter also. It's under the counter tab in service mode in the misc field, highlight it and hit clear. I hope this helps you.. Let me know...
Posted on Sep 14, 2009
    Brigadier General:
  • 3,513 Answers
Thank You for contacting Fixya.com.
A E005 is the cleaning web counter. If you have replaced the cleaning you can reset the web counter in service mode under counters. The service switch is right next to the total meter in the front of the inside cover of the copier. Once you press it you will see a little "$" sign shows and hit the "*" "6""*" and courser down the the web counter. You have to hold down the Clear botton and the hit the service switch to reset the counter back to zero.
OR
push *28* then copier>counter>misc-fix-web set to 0.
Have a nice day.
GodBlessU
  • 854 Answers
Push *28* then copier>counter>misc-fix-web set to 0.
  • 3,051 Answers
Hello there Here is a link that should be able to help you with your problem just follow the link carefully and there is some helpful things in there ok
best regards michael
  1. Printer Supplies - Popular & Hard-to-Find Copier, Fax and ... ... error it was most likely caused by a low power problem i.e. low ... On the HP Laserjet 4/4+/4Si/4V/5/4P/4MP the 53.XY.ZZ error code is decoded as follows: ...www.printersupplies.com/errors.html - 241k - Cached
Posted on Sep 12, 2009
Done shown as 005
A E005 error code means the fuser cleaning web needs to be replaced. It cleans & lubricates the upper fuser unit. It is the white web that rest above the upper fusing roller. There is also a web counter in service mode that will need to be reset as well. You can just rest the counter, but if the web runs out > the upper fixing roller will be damaged. Good Luck
Oct 04, 2011 | Canon imageRUNNER 400S Copier
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Malfunction(Code 3451) of Bizhub C252
This is a fuser heat error. The fuser unit is located in the area where the paper exits the machine. It heats up and "fuses" the toner onto the paper. The error code means that it did not heat up properly. This means you will most likely need a service person to come out and diagnose the problem.
You can try to reset the error but I doubt it will help.
Turn off the MAIN power switch (not the one on the control panel)
Now hold down the utility key while turning on the main switch and continue holding the utility key for at least 10 seconds. You should see a screen come up with nothing but "trouble reset"
Touch trouble reset and you should see a small "ok" come on. Then turn off then on the main switch again.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Office Equipment & Supplies
Xerox 5750 error code 005
this error comes from fuser unit u have to change fuser unit
Aug 19, 2009 | Xerox DocuColor 5750 Printer
Konica Minolta Di 3010 - cannot clear trouble message
one thing you can try since you have already removed the fuser you can probably do this but i would not recommend it unless you are familiar and comfortable with the components of the machine turn the copier off remove the back cover you will see in the middle of the machine a metal cover with 4 or 5 screws, behind this cover is the main board it has many wires going to it through out the machine...remove the cover so u can see the board and all its connectors on the board there should be a little black button... turn the machine on press this button and the code should reset. If the code does not reset then the thermistor or thermostats are bad and the fuser needs to be rebuilt. as for the password 8 zeros or 1-8 are the defult passwords for the machine. you can also try 1247....
Apr 03, 2009 | Konica Minolta Office Equipment & Supplies
I am getting errormessage as E 005 How can solve this problem in IR 400
"Switch Main Switch off and on after some time".if the problem still remains then It involves getting the fuser out of the machine
The fuser comes out relatively easy from the left access door. undo the metal straps holding it. Make sure the machine is unplugged, remove the connectors on the left of the fuser, as well as the exit sensor connector on the right. The green fuser knob inside the front cover has to come off too.The web needs to be replaced and counter cleared in service mode.
The web assy comes off with two screws. Make note of how it's wound, you'll want to make sure you put the new one on the same way.
Put it all back together. When you turn the machine on for the first time, you'll still get an E005, at this point, hit *,2 and 8 together,* to get into service mode. Under the heading "counter" then "misc" you'll find the web counter. Highlight it and hit clear. Turn the machine off and on, .
The odd time I've still had it give me a code, if this happens, get into service mode, "function" tab, "clear" then "error". Power off and on.
Feb 13, 2009 | Canon Office Equipment & Supplies
E 005
A E005 is saying the cleaning web needs to be replaced or the web counter needs to be reset...If the cleaning web is out it will cause more damage to your upper fixing roller
Jul 28, 2008 | Canon NP 6050 Copier
ERROR E005-0000 CANON C2058
Thae error means the fuser web has run out
you will need to replace the web and the reset the code in service mode.
You must replace the web before resetting the code if you dont
it will damage your machine.
if you want to know how to reset your machine please get back to me
Thank You
Feb 22, 2008 | Office Equipment & Supplies
E005
Hello bud,easy problem just replace your fuser cleaning web,and reset the counter.
Oct 24, 2007 | Canon NP 6050 Copier
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Canon C330D Copier Logo
143 people viewed this question
old marine
old marine
