Question about Prestige APS686T Remote Start and Keyless Entry System with Additi
I need a manual for APS686T for the wiring diagram. the remote start is not working.just power locks and alarm.
  • 436 Answers
Sounds like the unit is in valet mode or the hood switch is broken. check for the hood switch or look for a toggle switch that might be under your dash. if switch is located turn switch on and try remote start.
Posted on Sep 12, 2009
Unlock button does not work manual lock ok when you unlock with key alarm goes off
I presume if you tried to start the vehicle it would start and drive as normal, just with the alarm going off... If this is the case then depending on make/model etc. the problem is electrical in the alarm system. The alarm is activated by the button, but not with the key in the door. Get the button to work and the alarm will de-activate. This maybe simple, i.e.. 1st checks...battery in fob , or bad connection in fob. Car Battery voltage.. is it 12v.
2nd check faulty receiver/ bad connection somewhere in system. To check correctly you will need to know locations of alarm/remote locking components. Basically find and test fuses (probably won't be faulty with your symptoms but check nevertheless,) then find receiver, and visual check connections in circuit, (bad earths are the most common failing in remote locking). If not working by this point you may want to stop and seek help.
Otherwise you will need a wiring diagram and have some basic voltage drop testing skills to identify problem. Thus you will need to test switching circuit in the remote locking/alarm circuit. Positive side...is the voltage is .5v or more then wiring fault on this side ...negative side test the same way.. Even with wiring problems, receiver may also be faulty as it would probably still work with volt drop of up to about 2v total, . If total volt drop in under 1v then somewhere in the receiver (the switch) there is a problem. If you are on here asking, you probably won't be able to find problem in receiver and that is where you would need an expert.
Feb 24, 2015 | Cars & Trucks
How to remote start with a manual transmission
the alarm and the start remote have to be wire together, other wise will not work never ever, because the alarm should disarm the electrical system or the power to the car download the electrical car diagram in the internet. some times there is forums under the brand of your car and some one else already deal with these before and they can provide you the diagrams and all you need.
Nov 19, 2013 | C3RS730 LCD
I bought an add-on remote start that said it works with factory installed alarms and we can't get it to work. I have a 2003 chevy s-10 zr2. we were trying to find a wiring diagram but no luck to see if we...
The red/white wire needs to see two ground (-) pulses to start the car. The door lock wires in your vehicle are positive(+). So, you will have to use a relay to make this work. The diagram for the relay will be like so: red/white from autocommand to 30, chassis ground will go to 85 and 87, and tap into the blue wire and connect it to 86 of the relay. This way when you press the lock button on your factory remote, the positive pulse at 85 will activate the relay and make the connection with 87 and 30, sending a ground pulse to the red/white wire. The blue lock wire can be located at the body control module(BCM) located to the right of the gas pedal. There are a couple of 7mm bolts holding a plastic piece that needs to be removed to access the BCM. The door lock wire is in the brown plug facing the drivers side.
Jan 26, 2011 | AutoCommand Remote Car Starter Add-On
I'm looking to get the user manual for a car alarm: aps2k4sflcf.
Go to this site http://auto.manualsonline.com/manuals/mfg/audiovox/audiovox_remote_starter_product_list.html
and click on Platinum APS 686T - Audiovox Remote Car Starter Owner's Manual
and click on APS 686 - Audiovox 4 Channel Remote Car Starter Owner's Manual
Jan 16, 2011 | Prestige APS686T Remote Start and Keyless...
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
Need crossreference wiring on a 2008 dodge charger and aftermarket alarm
This link will get you 2007 which should be same. Good Luck.
http://www.the12volt.com/installbay/uploads/2007DodgeCharger.txt
Nov 03, 2010 | Dodge Charger Cars & Trucks
I need to disable my alarm on a 1997 bmw 528i.
Now im not sure since the manual says your model has the same alarm system as the 328i and on the 328i you can remove the module to disable by doing the following. you can unplug the control module. It is located under the glove box. Climb under the dash on the passenger side and remove a few screws on the trim panel under the glove box. Theres a black control module with a green connector. There should be a lock tab on the connector. press the lock tab and pull out the connector. The alarm should now be disabled. But if it has the special transponder key this may not work.
But if the only reason you want to disable it is because of the motion sensor setting of the alarm for no reason there is a solution for this. To disable the motion sensor, hit the lock button to arm, then hit lock button again within four seconds to disable motion sensor. Red light on rearview mirror should flash four times, then pause, then start flashing on regular intervals. this is most likely the reason if your having the issue where the alarm goes off every 20 minutes.
If you want to completely remove it below is a wiring diagram taken from the manual for you alarm system.
this is from the manual its the alarm wiring diagram.
Battery Constant 12v Positive Wire ( ): Red/White or RedBattery Constant 12v Positive Wire Location: Ignition Switch Harness
Starter Positive Wire ( ): Black/Yellow or Black
Ignition Positive Wire ( ): Green
Second Ignition Positive Wire ( ): Purple/White or Purple
Second Ignition Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire ( ): Gray/Purple and Gray/Yellow. Use Both Wires. This vehicle has a dual parking light system that will require 2 extra relays.
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire ( ): White/Red
Power Door Lock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Power Door Unlock Positive Wire ( ): Blue/Red
Power Door Unlock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Door Trigger Negative Wire (-): Brown/Gray
Door Trigger Negative Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Domelight Supervision Wire: Turns On With Unlock
Horn Negative Wire (-): Brown/Red or Brown/Yellow
Tachometer Wire Negative Wire Location: At Instrument Cluster
Brake Light Positive Wire ( ): Blue/Red or Green/Red
Factory Alarm Disarm Wire (-): Disarms With Factory Remote Only. Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: Transponder Anti-Theft System, Requires Bypass And Extra Ignition Key. The 1997 model year vehicle may require a bypass module and an extra ignition key, if vehicle is equipped with a special key from BMW.
Factory Anti-Theft System Location: Transponder At Ignition Switch Tumbler
if you require further assistance please let me know and i will help assist you from there. Thanks, Midwest-Tek
Aug 27, 2010 | 1997 BMW 328
How do i wire in a alarm on my 97 suburban K1500 i need a wiring diagram to find wire colors for windows lights and etc........
1997 Chevrolet Suburban Car Alarm Wiring Instructions
Battery Constant 12v+ Positive Wire (+): Red
Starter Positive Wire (+): Purple or Yellow
Ignition Positive Wire (+): Pink
Second Ignition Positive Wire (+): Pink/White Or White (This wire must be connected as ignition #2 for remote starting.)
Accessory Positive Wire (+): Orange
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Drivers Kick Panel
Power Door Lock Negative Wire (-): Light Blue (Type A)
Power Door Lock Negative Wire Location: In Either Door Harness
Power Door Unlock Negative Wire (-): White (Type A)
Power Door Unlock Negative Wire Location: In Either Door Harness
Door Trigger Negative Wire (-): Purple
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: White (-), Requires Relay
Domelight Supervision Wire Location: At Headlight Switch
Trunk Release Negative Wire (-): Black (+) Or Black/White (Requires Relay)
Trunk Release Negative Wire Location: At Hatch Release Switch Or Low In Drivers Kick Panel
Horn Negative Wire (-): Black
Tachometer Wire Negative Wire (-): White
Tachometer Wire Negative Wire Location: At ECM. The ECM (electronic control module) is located on the driver side inner fender.
Wait To Start Wire: When hooking up a remote starter on a diesel, you will need to program in the 5, 10 or 15 second wait to start timer in the installation manual. On some vehicles the wait to start light on the dash is not a true (+) positive or (-) negative and the wire from the remote starter will not work.
Wait To Start Location:
Factory Alarm Disarm Wire (-): N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Mar 31, 2010 | Brand Remote Start/keyless/car Alarm Very...
I need Wiring diagram for audiovox aps 510 c
GO TO
TECHSERVICES.AUDIOVOX.COM
DO NOT ENTER WWW
REGISTER AND CHOOSE INSTALL MANUALS.
Nov 29, 2009 | Prestige APS686T Remote Start and Keyless...
Dog Chewed my Prestige car starter
one purchasing the new remote audiovox will send you an instruction manual on the steps to programming the new transmitter. it is fairly easy, and they will give you the number to there tech department that if you have any trouble they will also walk you through it. hope this helps
Feb 24, 2009 | Prestige APS686T Remote Start and Keyless...
Prestige APS686T Remote Start and Keyless Entry System with Additi Logo
611 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
