Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1997 chevy truck taillight turns on when you start the vehicle and it stays on. as soon as you shut the engine off, the taillight goes out.
  • 986 Answers
Actually these truck are netorious for tail light blinker problems. I have a 98. I willing to bet the tail light socket is melted. you can buy a new one from chevy for 65.00. here is the good thing wait a few weeks then return the old one for a spare. If and when the other side goes out get a new one and in a few weeks take the old one back. These parts have a 1 year craftmanship coverage. So you can swap them out. That way you always have a spare in the garage.
Posted on Sep 12, 2009
  • mvsfan Aug 31, 2010
    i found my own solution to this. somebody had at one time installed a 5th wheel in this truck and then they hurriedly tore out the 5th wheel equipment and their custom wiring and zip tied the remaining mess inside the frame rail before they sold it.
    My solution after discovering this was simple. i went to a local salvage yard that i deal with frequently, and got the entire rear wiring harness off of another truck.
    I removed the bed of the truck, tore out the whole mess and put the new one from the cab back in.
    Problem solved, at a cost of $100.00.
3000GT 1992 First issue was ongoing, turn signal sometimes shuts off engine. Then headlamps wouldn't come up and door panel lights stay on after locking and leaving.
I would look for a faulty electrical connection somewhere, especially, the ground connections. After 10 years, some electrical connections build up resistance and need to be cleaned up. With a bad ground connection, things get unpredictable.
Nov 10, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
Dead battery after turning the vehicle off, and trying to restart.
Pull the battery take it to any of the chain auto parts stores and have it tested, I bet the battery is no good.
Aug 31, 2017 | 1997 Oldsmobile Aurora
Check Engine sign comes then engine rattles Hyuindai Sonata 1997 GLE
Hi there:
When the light comes on, one or more diagnostic trouble codes (DTC) are stored in the engine control module. These DTCs remain even if the light goes out. To address a Check Engine Light problem, the DTCs are retrieved and the appropriate troubleshooting information is followed in order to determine the problem.
The four most common Check Engine Light scenarios and what to do:
* The Check Engine Light turns on and off or flickers.
If the Check Engine Light comes on in the city but goes off on the freeway, then the fault is present during city driving conditions. Pay attention to whether or not the vehicle runs or drives any differently when the Check Engine Light illuminates. If vehicle performance does change, drive the car as little as possible and take it to be checked by a service professional as soon as possible. If there is no change in vehicle performance, you can drive home, but have it inspected as soon as possible. In this condition, you run a risk of the vehicle dying or not starting.
* The Check Engine Light comes on and stays on.
If the Check Engine Light illuminates constantly during driving with no noticeable driving or performance problems, there is a permanent fault in the emission control system. When this happens, the computer that controls the emission system usually has a backup program that runs while the fault is present. (These backup programs are often referred to as "limp home" mode programs.) You should get the vehicle serviced as soon as possible, but in most cases, the vehicle will continue to operate, though you run a risk of it dying or not starting.
* The Check Engine Light illuminates, stays on, and there are performance problems.
This means that a vital component of your emission control and engine management system has a serious problem. It usually involves a component or system needed for the vehicle to run at all. In most cases, drive the vehicle as little as possible. In many cases, the vehicle is not safe to drive at all -it could stop or stall out at any moment. It is best to pull over to a safe place and have the vehicle towed to an automotive diagnostician for a thorough inspection and repair.
* The Check Engine Light light comes on and blinks in a steady pattern while driving.
Don't confuse this steady pulsing of the Check Engine Light light (usually one or more flashes per second) with a flicker (see above). The Check Engine Light may stay on steadily or it may flash when the vehicle is accelerated. This is very serious. There is a severe failure of the emission control system that is causing the engine to misfire to the point that the catalytic converter is damaged each time the Check Engine Light flashes. It may mean that the catalytic converter is overheating to the point that it will glow red or, in extreme cases, start a fire on the underside of the vehicle. Immediately pull over to a safe place and have your vehicle towed to an automotive diagnostician for repair. Vehicles can be severely damaged and even destroyed by fire if this condition is ignored for too long.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 21, 2012 | 1997 Hyundai Sonata
1995 chevy cavalier passlock reset
Here is how to do the relearn. Turn ON the ignition, with the engine OFF. Attempt to start the engine, then release the key to ON, vehicle will not start. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF. Turn OFF the ignition, and wait 5 seconds. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes, the vehicle is nowready to relearn the PasslockTM Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important: The vehicle learns the PasslockTM Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. Start the engine. The vehicle has now learned the PasslockTM Sensor Data Code and/or password.
Thank you for using Fixya and just take you time and follow the instructions above. Good luck
Mar 20, 2010 | 1997 Chevrolet Cavalier
97 Chevy Truck starts and idles rough and then shuts down
Sounds like you're loading up with fuel. I'd check the fuel pressure regulator. Some engines are set up with a regulator inside the intake plenum, which requires plenum removal.
Oct 01, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
83 chevy truck starts then dies off. wont stay running
when it shuts off is it a warm engine condition going into closed loop , no check engine light ?
Aug 04, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
"Service Engine Soon"
un plug the batt and turn the switch on and try to start it for 20 sec then reconnect the batt the service engine soon light will be off if ther is no reason for it to be on
Feb 17, 2009 | 1997 Chevrolet Suburban
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
52 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
