Question about Samsung CLP-510 Laser Printer
Same problem, different printer
Samsung CLP-510 on DLink router with USB port share. Two weeks ago it worked fine from every computer in the house. Now it prints test pages but documents evaporate as if never getting queued. Same happens if I plug it direct to a computer and try to share it that way. Personally I think Microsoft broke something in an update to Windows7
SAMSUNG CPL 510 USB printing problems
replace cable with new one, if you tried the unit with two systems and came up with same fault.
Mar 14, 2014 | Samsung CLP-510 Image Transfer Unit...
My Samsung clp 510 printer won't print in color. How can I fix it??? I just installed a new black ink toner cartridge and now it's not letting me print in color. About a month ago I replaced the color...
I had a similar issue with my 510. My printer would only print in b&w regardless of my settings in the printer setup. I uninstalled my printer driver and reinstalled a fresh one from disk. This cleared up my issue.
Mar 26, 2010 | Samsung CLP-510 Laser Printer
The samsung clp 510 does not power up. It was prinitn and working fine. Walked into the room to print and found it Dead.
If you had a power surge or something, it could have knocked out the SMPS, power supply.
# jc96-00055a.
Sep 04, 2009 | Samsung CLP-510 Laser Printer
Wrong clp 510 toner
samsung clp 500 toner cartridge can not use samsung clp 510
bcase clp 500 is without chip and clp 510 chip base cartridge so never u can user.
Dec 27, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 not printing
hi ,
i went through the website www.linksys.com and i found that Samsung CLP-510 is not compatible with wrt160n.
Oct 23, 2008 | Computers & Internet
Samsung clp 510
usually happens when the NIC card goes bad, may need to replace.
first try resetting the printer, look in your manual
Aug 25, 2008 | Samsung CLP-510 Laser Printer
CLP-550N problem with MacOS 10.4.7
Don't know if this would work:
from: http://www.macintouch.com/tigerreview/incompatibility.html
"I have one and have just finished preliminary testing. I have a CLP-550N and use the network port to connect the printer to our wired network. Using Bonjour (a.k.a. Rendezvous) does not work. I can successfully setup the printer, but it will not print. LPD, however, does work fine. You may need to reinstall the PPD files from the CD, or download them from there (sic) website." Brad Scheider reports: "Samsung no longer supports a CLP-500 driver. But I've found that the CLP-510 Driver works in Tiger and fixes many problems I had with the CLP-500 driver on Panther. Works great now."
Apr 09, 2008 | Samsung CLP-550N Laser Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 not printing?
Most probably you are using an USB cable that is either too thin (cheap cable) or too long (beyond 6ft.).
Oct 22, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
57 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
