Question about Teac AG-V3050 Receiver
Teac ag-v3050 speakers a and b
I have a teac ag-v3050. It was given to me. I cannot get the speakers a and b to work at the same I can get either to work but not both.
Is that normal?
Martin Green
SOURCE: Teac AG V8050
try using an antenna.
Posted on Jan 31, 2008
SOURCE: TEAC AG-D9100 freeze
Always be that legend when the audio amplifier IC damaged
Posted on May 08, 2009
  • 7 Answers
SOURCE: fuse blows everytime i turn it on
the blue coloured varacter in your power supply circuit needs to be changed
Posted on Jul 12, 2009
  • 4234 Answers
SOURCE: My TEAC AG-7D turns on for about a second but then turns off
There is a problem in the final stages of the amplifier section that the protection circuits are detecting. They then shutdown the unit to prevent further damage. The most likely candidates are the output transistors. This is a relatively simple repair for an audio shop. Expect a parts cost between $20-$45.
Posted on Jul 16, 2009
SOURCE: Teac AG-V8525 Stopped producing sound. Has legend says "protect"
hit reset button back of receiver
Posted on Dec 02, 2009
SOURCE: Teac AG-V8520
same problem exactly
Posted on May 31, 2010
0 characters
1 Points
No sound from receiver
is the test tone loud or at the same level. you need to check the volume level of your player dvd, cd to make sure it's all the way up some players have volume level built into them.
Apr 12, 2014 | Audio & Video Receivers
Teac AG-V3050. Everything looks right but puts out no sound to speakers. Have trien many speakers. Is there a fuse, reset, etc? Thanks
I nce had the relay for the amplifier die on one of my receiver. Basically this will allow the amp to power on and supply voltage to the speakers. Same thing though, i could access all of the menus, adjust setting, and volume but no sound because the amp never clicked on.
Oct 19, 2012 | Teac AG-V3050 Receiver
My AG-V3050 pro-logic receiver seems to have a volume control issue. The test mode volume works fine but when I switch it to fm the sound is very weak, I have to crank it all the way up to get a little...
Two dump question and than recommendation..
  • First ;During listening FM ,Your " MUTE" switch is "ON" or "OFF" ? if not how about plain STEREO mode ? did you try it ?
  • about the other Modes , i.e ..CD ,DVD etc. ? same problem or it happens only in FM ? the possible solution;
sometimes FM stations do not properly triggers pro-logic circuit and cause such problem and you need to switch to STEREO or A.F.D mode to listen FM (AFM includes sub woofer)..
This is true for FM only and it should not happen in other modes as DVD ,CD,Phone etc..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 29, 2011 | Teac AG-V3050 Receiver
I just want to know the wattage on the Teac AG-V3050
Teac AG-V3050 and Teac AG-V8050 are very compatiable to help with this question the total watts per channel are 100 watts. Hope this answers or at least helps. Excellent unit, great power to supply great sound for the unit at its time.
Jan 24, 2011 | Teac AG-V3050 Receiver
TEAC AG-V3050 FM reception was fine and then quit. Checked antena with no results. Internal component? Fuse?
If a unit turns on it isn't a blown fuse. Does the tuner give you indications that it is or is not tuning a station? Change the FM Mode to Mono. You should at least be able to hear FM hiss if the tuner is alive.
Jan 20, 2011 | Teac AG-V3050 Receiver
Teac ag-d9100 center and surround speakers are not working , very very low volume.. the others all work fine. Anybody know where to start troubleshooting. Its not a fuse that I can see , at least that i...
You have to enable them and turn the volume on them up separately with the speaker config, level trim, and up/down select buttons on the remote. You can also adjust the rear speaker delay time or just hit the test tone button and adjust the volume on each speaker separately as it goes through them one at a time...
Jun 01, 2010 | Teac AG-D9100 Receiver
Lost not know what is the difference sound surround
Hi use this link to download the manual .
Take care.
May 18, 2010 | Teac AG-V8060 Receiver
Fuse blows everytime i turn it on
Mar 30, 2009 | Teac AG-V3050 Receiver
I have an older TEAC AG-V3050. It continues to turn off when i turn the volume knob up, for ANY sound. Any ideas?
Output driver work is needed. Also, check all speakers for damage or failure...accordianman
May 10, 2008 | Audio & Video Receivers
Audio & Video Receivers Logo
51 people viewed this question
Top Teac Audio & Video Receivers Experts
Are you a Teac Audio and Video Receiver Expert? Answer questions, earn points and help others
