Question about Dryers
Dryer was working and finished a cycle. I tried to turn it back on. When I press the start button it will beep but the drum will not spin. It seems to go through the cycles and will beep and show that all cycles have completed. Except it never started at all. I don't hear a motor or anything running and the drum does not spin. I have a Maytag EPIC MED9700SQ.
  • 986 Answers
Usually this means the belt is broken,the belt may have just been old and worn out and it was time to replace it,or perhaps the wheels locked up or the idler and caused the belt to break. Look around for stiff wheels, bad bearings, glides and idlers. Its a good idea to oil the rollers with some temp resistant oil such as zoom oil. Dont use WD40 as this stuff is highly flammable and may cause a fire.
Posted on Sep 12, 2009
Drum does not turn
Try pulling the electric motor out and running power direct with an extension cord to see if it comes on. If it comes on then you have some kind of electronic problem or a short, If the motor doesn't come on then it is bad. Just be careful to not electrocute yourself.
Feb 18, 2014 | Samsung Dryers
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
After choosing dryer cycle by turning the selection knob, I try to start cycle by pressing big Start button. It beeps several fast beeps. Also the drum light just stopped coming on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 20, 2010 | Whirlpool GEW9250 Electric Dryer
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Electric dryer won't start
Your problem sounds like it could be a broken belt, faulty motor, or maybe the belt has slipped off of the motor or idler arm pulley.
You can try this first:
Uplug the dryer, reach inside and try to turn the drum 1/4 to 1/2 turn, the plug the dryer back in, and push the start button. Sometimes motors will get dead zones in them and this will move it from that zone.
If you attempt the repair, and if you have a front loading machine, you would remove the front of the machine, this will expose the drum and belt, you can now check the belt to see if it is ok. If it is ok, then you can remove the drum and belt and this will expose the motor, idler arm with pulley and drum rollers.
While you have the drum out of there it is a good time to check the condition of the drum rollers to see if they have flat spots on them, if they do have flat spots on them, then need to be replaced. If not then I recommend that you lubricate them at the shaft with a good grade of Machine Oil such as 3 in One oil. This will save problems later.
Good luck,
I hope this helps you
Oct 04, 2009 | Whirlpool LER5636P Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer won't start. Pressing "Start" button just emits 4 beeps.
does the drum turn? if it doesnt you can assist it and see it that is problem, have to remove top and push it. that would be capacitor on motor or jumper the door closed switch and try to spin.
Apr 21, 2009 | Dryers
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
104 people viewed this question
Top Dryers Experts
