Question about Evenflo Generations
I have the same problem! I can not remove the arm rests.
MY pad stinks......???? I can not remove the armrests. why would you make a carseat for CHILDREN and not be able to clean it......DUMB!
Please help if you can!
  • lejabeck Sep 12, 2009
    I figured it out!!! it drove me nuts! but you have to kind of pullout the little tab behind the arm rest just so to get the part on top to push behind it. then it will come out. it is a little hard at first but you will get it!
  • 4 Answers
Thanks for this! I just wanted to add that it's much easier to pull the bottom tab towards you if you have a pair of pliers! Then sliding the top tab underneath is super easy!
Posted on Jan 21, 2010
Thank u god
Posted on Oct 17, 2009
How do you remove the armrest in a 1989 Chevy K5 Blazer?
The padded part of the armrest has a screw underneath. Once you have it off you'll see the other screws it hides. Take them out and the armrest is off.
Sep 07, 2014 | Cars & Trucks
Armrest on passenger side door
sometimes yes..there are bolts and screws that hold it on..take those out and the armrest should come off..(padded part anyway..)then you can decide on a salvage part or try to put something else on it..
Dec 22, 2013 | 2000 Dodge Intrepid
How to remove maxi cosi cabrio harness straps
Hi
The harness of a carseat should never be removed or replaced by anyone other than a trained engineer due to the safety implications of it being incorrectly replaced.
The carseat fabric should be removed from this carseat and they can be washed - the harness itself should be cleaned in place in the carseat using a solution of stain remover and water and a small scrubbing brush or hard scourering pad to clean the harness. Excess water in the carseat should be dried immediately and thoroughly to prevent any parts rusting. Loose crumbs can be removed using a vacuum cleaner.
Alternatively the carseat can be sent in for the engineers to replace with a new one. Inspection and single repair (replacement of the harness) plus safety checks and courier collection and repair can be booked for 39.99GBP if you're in the UK by calling 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Mar 22, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
My Child is jumping out of the Straps (even it's tight enough)
Children are copy-cats. They watch your every move so closely and repeat it to see what happens when they do it. You're aware of them doing it a lot of the time - many people avoid swearing in front of their children, some people don't like arguing in front of them, you allow them to see you using the loo and brushing your teeth by way of encouragement of what they need to learn.
So what about when they copy the bad stuff? Stuff that we, as parents, need to do, but stuff that they really shouldn't. Stuff like opening the oven, pouring boiling water from the kettle, opening the buckle of their harness on their carseat.
Well, it's down to parental guidance: "Don't touch the oven", "Don't play with the kettle", "Don't undo the carseat harness". Most often than not, you'll follow up that statement with a reason - "Don't touch the oven - it's hot, and it might burn you". It's the same with the carseat harness buckle - you have to provide a reason why it's important for them not to undo it.
There are various pages set up on the internet to help parents with techniques for discouraging children from undoing their carseat harness; Tips such as making it into a game, demonstrating to them how everyone must wear a seatbelt and explaining the importance for it on a level that the child can understand, whether they're a curious toddler or a bored six year old. In addition, distraction techniques can be helpful, and for younger children the Maxi Cosi PlayTray will fit onto all the Group 1 carseats in the range, providing not just entertainment but also making it more difficult to access the red release button.
The Maxi Cosi carseat range requires a pressure of 60 Newtons of force to open it. This is the maximum allowed under UK safety law so we can't make it any harder to undo. To make it more difficult for the child to undo the harness, always ensure that the harness is adjusted to the appropriate height for their shoulders (it should be no more than an inch above or below their shoulder height) and also check before every journey that the harness has been properly tensioned. You should only be able to fit 2 fingers between the childs chest and the harness once it is correctly tensioned as per the user manual. While the child may not like being restrained in the carseat harness, you aren't hurting them by ensuring it's correctly tightened before each journey, and you must remember in the event of an accident you want the harness to be nice and secure to prevent them flopping around in the carseat.
The harness must be completely released by a single, red push button. This is the universally recognised seatbelt and carseat release button, and in the event of an emergency if someone other than yourself needs to get the child out of the carseat quickly they need to be able to do so easily and without specific guidance from yourself on how to do it, so adding things to the harness is not advised and some additional chest clips are in fact not legal for use under UK law.
If you're on a long journey and the child falls asleep, you may find that the harness appears looser on them than it did when you first set off - this is as they've relaxed, and as the harness is not self-retracting like an adult seat belt it may become loose as their posture changes in the seat. In this event, if you were to have an accident at this point, the harness would prevent the child from moving any further forward from the position they were originally in; the carseat harness has not loosened off at all. In the event that you're concerned about the amount of additional gap when the child falls asleep, pull over when it is safe to do so and give the tensioner strap that extra pull to remove the slack. If you're not sure that you are able to fit the carseat and tension the harness correctly, please refer to the website for video demonstrations on fitting the carseat, or ask your local retailer for a refresher lesson in how to correctly fit and tension it.
These sites are worth having a look at if you encounter the issue of your child trying to get out of the harness, whether they are releasing the red button or attempting to slip out of the harness any other way:
http://www.childcarseats.org.uk/choosing/children_undoing_belts.htm
http://www.trafficclub.co.uk/
http://www.dft.gov.uk/think/education/early-years-and-primary/
May 23, 2012 | Baby Gear
Hi, i cannot get my maxi cosi to recline. can you offer any help with ideas?
Hi Lorna - Most commonly this issue is caused by dirt/debris getting caught in the tensioning strap of the harness and gradually pulled into the mechanism of the carseat over time. First recommendation is to remove carseat from the car and remove cover (do not remove harness system from seat) give the carseat fabric and the seat itself a clean and see whether this improves the recline situation. If not, please contact your customer services department - if you're in the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Aug 11, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
How do I remove the door panel and replace the inside door handle
PLEASE DON'T FORGET TO RATE!!
Door Panel
  1. Remove the door handles and the locking knob from the inside of the doors.
If equipped with screw retained door pull handles, remove the screws through the handle into the door inner panel.
  1. If equipped with remote control mirrors, remove the remote mirror escutcheon, then disengage the end of the mirror control cable from the escutcheon.
Door lock remote control handle
Removing the clip from inside the door handle
3. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switches and the cigar lighter (if equipped) from the electrical harness.
4. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
View of the armrest switch cover plate and remove mirror cable attachment
  1. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
If equipped with electric switches in the door trim panel, disengage the electrical connectors from the switch assembly.
  1. Along the upper edge of the lower trim panel, remove the mounting screws. At the lower edge of the panel, insert tool No. BT-7323A between the inner panel and the trim panel, then disengage the retaining clips from around the outer perimeter. To remove the lower panel, push the panel down and outward to disengage it from the door.
If equipped with courtesy lights, disconnect the wiring harness.
  1. If equipped with an insulator pad glued to the door inner panel, remove the pad (with a putty knife) by separating it from the inner panel.
To install:
If replacing the inner pad to the door inner panel, use 3M General Trim Adhesive No. 8080, glue it to the panel.
  1. If removed, glue a new inner pad to the door inner panel.
If equipped with courtesy lights, connect the wiring harness.
Exploded view of the window regulator handle
Exploded view of the door trim panel
  1. Engage the retaining clips around the edge of the lower trim panel, then install mounting screws.
If equipped with electric switches in the door trim panel, engage the electrical connectors to the switch assembly.
  1. If equipped with two-piece trim panels, engage the retainer clips to the front and the rear of the upper trim panel.
  2. If equipped with an integral armrest, install the retaining screws.
  3. If equipped with a switch cover plate in the door armrest, engage the switches and cigar lighter (if equipped) harness connectors, then install the cover plate and secure using the plate screws.
  4. If equipped with remote control mirrors, engage the control cable, then install the remote mirror escutcheon.
If equipped, install the pull handle screws through the handle into the door inner panel.
  1. Install the door handles and the locking knob to the inside of the doors.
Exploded view of the 2-piece door trim
  1. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switch
  1. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
  2. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
To install:
  3. If equipped with a switch cover plate in the door armrest, engage the switch harness connector, then install the cover plate and secure using the plate screws.
Nov 16, 2009 | 1987 Chevrolet Monte Carlo
Can't get the armrests off to clean the cover
You CAN remove the armrests- quite easily actually! All you need to do is grab a small pair of pliers. Behind each armrest are two tabs. With the pliers, pull the bottom tab out. Slide the top tab underneath the bottom. The armrest will pop right off! Which means you can wash the pad seat and all!
Sep 22, 2009 | Evenflo Generations
Cannot remove the armrests
Grab a pair of pliers! With the pliers, pull the bottom tab out towards you and slide the top tab underneath. Once the top tab is under the bottom, the armrest will pop right off.
Aug 09, 2009 | Evenflo Generations
Need to replace the driver's door interior door opening assembly
Hi there.
The procedure is roughly the same for all mk3 x types.
You need to remove all the screws on the armrest and on the ashtray, then undo all the plastic clips using screwdrivers on the panel.
You find detailed instructions on links below, I quote:
" remove two screws at the bottom of the armrest.
pull out ash tray.
remove screw in the middle of the ash tray holder.
pull up on armrest, it should pop up, then pull it out
start at bottom right of door and start popping out the plastic clips (all the way around the door)
(remove speaker wires)
push up door panel - done"
WikiAnswers - How do you remove a rear door panel in a Jaguar XJ6
Also from manual:
Disconnect vehicle battery ground lead.
Remove the door trim pad veneer panel.
Remove the upper trim pad.
Remove the door armrest.
From inside the door pocket, release the puddle lamp (1 Fig.1) securing quarter turn fastener.
Undo and remove fixing (3 Fig.1), (front door only)
Carefully release lower trim pad fir tree fasteners.
To avoid damage and distortion of the door metal, lift the lower trim pad complete with clip and clip retainer.
Carefully pull the trim pad away from the door panel.
Disconnect the multi-plugs (1 Fig.2) and remove the lamp.
Carefully displace the trim pad (2 Fig.1) from the door retaining clips.
Disconnect the multi-plugs (2 Fig.2) and (3 Fig.2).
Remove the door pocket.
Displace and remove the retaining clips and remove the trim..
Refit in the reverse order of the removal procedure. Check the trim pad retainers for damage before refitting.
Before refitting the lower trim pad, remove the clip retainer from the pad and and reposition retainer to the door.
ndo door handle escutcheon screw and remove escutcheon
Undo and remove the upper trim pad securing screws.
Remove the chrome strip.
Undo and remove the top channel securing nuts.
Displace and remove the top channel assembly.
Place the trim pad aside (Fig. 1).
Thanks Jaguar XJ6 Interior Lights
I will be grateful if you can rate the solution given.
Many thanks.
G.
Feb 25, 2009 | 1995 Jaguar XJ6
Need help
https://plweb.evenflo.com/faq_detail.aspx?faqid=4990 Question: How do I care and clean for my PortAbout 3/PortAbout V infant car seat? Answer: To clean pad slide the elastic loops of the seat pad off of the seat shell. Remove the harness system. Cloth pad, canopy, and head support may be machine washed separately cold water, delicate cycle, tumble dry 10-15 minutes, low heat. Wipe straps, buckles, and harness adjusters with warm damp cloth and mild soap. Air dry. NOTE: DO NOT submerge harness assembly in water. To help protect the vehicle upholstery, place a towel beneath and behind the child restraint.
Feb 23, 2007 | Evenflo PortAbout 5 Infant
Evenflo Generations Logo
290 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
