My dell v105 paper jam light keeps flashing even tho there is no paper jam. Have turned off and on again several times. Printer has just frozen and paper feed button does not do anythin.. HelP!!!
    Genius:
  • 1,043 Answers
There might be either a small piece of paper or dust covering the sensor. Take out all of the paper from the printer. Using a can of compressed air blow out the entire paper path. Try the printer again. If it still doesn't work then you may have to get the printer serviced.
Posted on Sep 12, 2009
Hi im trying to install and get going a lexmark 1250 the paper keeps jamming i think i have that fixed but now the power light keeps flashing and both inks are filled what could be wrong with this now i...
Most of the time this can be fixed by turning off the printer on the mains supply, leaving it for about 15secs and then turning the printer back on again.
A lot of the time a flashing status light either means that there is (or was) no paper in the printer, therefore you'll need to add some and press the paper feed button. Or the paper has jammed so you need to remove the blockage and reset the printer (turn it off and back on by the mains).
Most problems can also be solved by restarting your computer.
Regards,
Jul 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
Paper Jam
Have you checked for paper jammed in the rollers or any other small item like a paper clip? Also are you running this on wired or wireless connection?
Jan 13, 2010 | Brother MFC-7820N Printer
All lights on Dell 1710 printer panel simultaneously flashing.
do you or have you recently started using recycled paper. I know for a fact that recycled paper and Dell printers dont get along very well. It's the dust and it will block the hole for the sensor which could show an error or make the printer think there is a paper jam. Youneed a can of compressed air and thoroughly clean it out. If that does not work you can remove completely the software from the pc, let the pc reboot and reload the drivers and software. good luck
Sep 21, 2009 | Dell 1710n Laser Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Paper Jam
try these steps
alternative :
Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
try this
alternative :
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
217 people viewed this question
jasbo
jasbo
