Question about Texas Instruments TI-5019 Calculator
How do I open case to change the ink supply roller
The print is very light and need to replace print roller. How do I open the case to get to the print roller. Also, exactly how do I change the roller unit.
2 Suggested Answers
SOURCE: where can I get an ink roller for my TI-5032-SVC calculator?
http://www.heasterlawson.com/tein50blinkr.html they sell the inks
Posted on Apr 21, 2009
I need to know why the receipt is very light when printed
If it is an ink printer, the ink ribbon or roller is probably running out of ink. Buy a new roller or ribbon and try it.
If it is a thermal printer, the paper rolls may be low grade. Try buying thicker high grade paper rolls. If that doesn't work, the print head in the printer probably needs replacing.
Check your manual to see which type you have. If you need a manual, try these guys https://the-checkout-tech.com/cashregisters.php
Jun 08, 2017 | Retail Supplies
Casio HR-100TM. is there a demo step by step on replacing ink.
The ink supply is a small roller. Remove the clear plastic cover over the (printed) paper and the roller will lift out. It only takes a couple minutes to do the job. I suggest not wearing anything white as you will probably get a little ink on your fingers.
Nov 23, 2016 | Casio HR 100TM Portable Printing...
How do I clean rollers on my dell printer
Anonymous,
How to Clean Your Printer's Rollers
  1. Turn Off Your Printer - Use the power button to turn off your printer. After it has successfully powered off, unplug it. You don't want any power coming into the machine while you are cleaning it.
  2. Let it Cool Down - Even if you haven't printed anything recently, you should still let your printer cool down for a few minutes. While it's on standby, it can build up a decent amount of heat. The last thing you need is to burn yourself while trying to clean its rollers.
  3. Remove the Paper Tray - In most cases, you will need to remove the paper tray in order to gain access to the printer rollers. This is usually as simple as pulling it right out. You will have to remove any paper that is in it first. If you're unsure about how to remove the tray, refer to your owner's manual. Don't force the tray out of your machine. You could inadvertently damage it by doing so.
  4. Remove the Ink Cartridges - This step isn't always necessary. If the ink cartridges stand between you and the rollers though, you will have to remove them. Simply remove them as if you are going to exchange them for new ones.
  5. Have Your Supplies Ready - You probably already have what you need to clean the printer rollers. A lint-free cloth is a must, and water will generally suffice. If you'd prefer, you may also use isopropyl alcohol. However, you should wipe the components down with water after cleaning them with the alcohol. If you don't, an oily reside could be left behind, and it could have a very negative impact on print quality.
  6. Clean the Rollers - Now it's time to get down to business. Lightly dampen your lint-free cloth with water or alcohol. Squeeze it out to ensure that it's not too wet. Hold the cloth in one hand and press it lightly against the first roller. With your other hand, gently rotate the roller until you have cleaned it all the way around. Be extremely careful. Do not use too much pressure. You might have to run it through a few times to remove all of the residue.
  7. Repeat for Each Roller - Simply repeat the same process for each printer roller.
  8. Get Ready to Print - Once you're satisfied that the rollers are clean and dry, replace the ink cartridges. Replace the paper tray and load it with paper. Plug the machine back in and power it up again.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
#iwork4dell
Sep 10, 2014 | Dell 926 All-In-One InkJet Printer
How do you change the ink roller in a TI 5005 ii
Replacing the Ink Roller
  1. Press the OFF button.
  2. Remove the printer compartment cover.
  3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
  4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
  5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
Nov 18, 2013 | Texas Instruments Office Equipment &...
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Printing (text suddenly blurry bold after closing lid).
open the toner access door remove the toner, slowly lower the tone access door and ensure that the top roller (charge roller) is lowering straight. the roller in the bottom of the cavity (the transfer roller) push down on this to ensure that it has spring tension. if the top one is level and the bottom one has tension then you'll need to change the high voltage power supply.
Jan 15, 2009 | OKIFAX 5780 All-In-One Led Printer
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Sep 30, 2008 | HP LaserJet P2015n Printer
Texas Instruments TI-5019 Calculator Logo
105 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
