Question about Pioneer DEH-P6900UB CD Player
Pioneer DEH-P2600
Good Day To All,
Can anybody please help me to provide a wiring diagram from my head unit (DEH-P2600) to my amp Premier GM-X822. I only got 1 sub, and it will be connected to this amp i got all my speaker will only used to amp from my head unit. And lastly I don't know what is the blue and white stripe wire from my head unit the rest of wire is ok.
Thanks
    Sergeant:
    Champion:
  • 362 Answers
Blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Posted on Dec 12, 2007
How to i install a Pioneer DEH-1250 to a Jensen 5500?I got these as a gift and its like confusing me.Please help me out and send me a diagram on the input wiring from the Pioneer player to the Jensen 5500-...
Hi, what you want to do is just connect the speaker wires from the head unit straight across to the pre-amp inputs of the amp. If you have a sub, also connect the pre-amp outputs of the head unit to the 2 sub inputs of the amp. Connect the blue wire of the head unit to the turn-on terminal of the amp and connect power wires to both units. May I ask what speakers are you using?
Aug 14, 2011 | Jensen Car Audio & Video
I'm not sure which wires to splice together
Hello my name is Isrel. Here is a diagram that will help you out.
Aug 24, 2010 | Pioneer DEH-P2600 CD Player
Aux location on head unit of pioneer deh-p7500mp
there should be two aoxzilurey wires on the back you stereo red and white! plug in your male wire to the female on the back of your stereo
Feb 23, 2010 | Pioneer DEH-P7500MP CD Player
Pioneer deh-p2600
Here you go. Use the link and download the diagram when you get there.
Good luck.
http://audio.manualsonline.com/manuals/mfg/pioneer/dehp2600.html
Jul 05, 2009 | Pioneer DEH-P2600 CD Player
I need a wiring diagram for deh-p400, the old one...
No diagram available for 10yr old head...sorry:o(
Other than that, it should be easy to hook it up, I'm sure there's no sub-outs etc. Should have 4 sets of speaker wires bundled together coming out of the back of the radio chassis. Yellow, is switched power...all the speaker wires have a stripe on one of each of the two wires, thats the "common" wire. White is ground for the chassis.
Good Luck
Jun 14, 2009 | Pioneer DEH-P4000UB CD Player
Can not find a wireing diagram for a pioneer DEh-p2600
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 30, 2009 | Pioneer DEH-P2000 CD Player
I have a Pioneer Premier deh-p330 player,illumination color
CLICK HERE for your manual.
Unfortunately for you, this Head Unit does not have the function you want.
The display is green by the factory, and the type of display installed cannot be changed or customized.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 25, 2009 | Pioneer Premier DEH-P580MP CD Player
Pioneer Deh-2300
The wiring colors are the same on all major brands of head units it goes a following:
Red: swtiched +12
Yellow: constant +12
Black: ground
Orange/white: dimmer
Yellow/black: cell phone mute
Blue/white: amp turn-on
White:FL speaker +
White/black:FL speaker -
Gray: FR speaker +
Gray/black:FR speaker -
Green: RL speaker +
Green/black: RL speaker -
Violet: RR speaker +
Violet/black: RR speaker -
I hope I could help. Good luck
-Andrew Hawkins
Sep 12, 2008 | Pioneer DEH-P4100
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Pioneer DEH-P6900UB CD Player Logo
679 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
