Question about Fisher and Paykel DEGX1 Electric Dryer
My Fisher & Paykel dryer is not putting off any heat. I just cleaned out the entire vent run system in my home and that did not solve the problem?
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
My fisher and paykel dryer will not heat
Check all the fuses on the unit with an ohm meter. Also go to you tube for visuals on how to do this
Feb 23, 2015 | Fisher and Paykel Dryers
Fisher and Paykel dryer dries clothes on medium heat but shuts off repeatedly if I set it to normal dry setting.
you probly have a venting problem disconect the vent from the dryer and try it see if it works ok if so get someone to clean vent ducking out.
Mar 26, 2014 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel dryer resets repeatedly
this indicates it is getting too hot try running without vent attached if it runs ok it is a pluged or crushed vent
Nov 19, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Pakel dryer wont heat all the time
open round housing on left inside where the lint catcher is. clean it. if that not solve your problem then replace reset switch. hope it will help you.
May 01, 2017 | Fisher and Paykel DEGX2 Dryer
My fisher paykel dryer is 3 1/2 year old. It works fine on med and low heat. On high heat, it heats up too much and turns itself off
clean the dryer of lint inside and also the vent tube:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
How can i reset an electric dryer fisher & paykel it runs but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel smartload dryer degxius does not dry cloths. Drum is hot, and lint basket is empty. I have cleaned lint out behind lint basket.
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Sep 04, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heatin element broken on my fisher & paykel dryer model # DEGX1
Try doing a Google search on the internet...put in your model number and make...look for parts
Sep 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
My fisher paykel DEGX1 won't heat up. everything else works fine.
If you have the same I do then it's the circuit breaker on the heating element. You have to take the front of the dryer off: Two screws on the top under the caps. Then lift the top alittle and you'll see the two screws on the front top sheet metal. The front then can be removed by pulling each side out and forward. The orange button is all the way at the bottom. Push and you'll hear it click.
Mar 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
161 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
