Question about Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput
I have an older 100,000 btu Reddy unit that was pulsing. Put new diesel in and problem went away for awhile. Now pulsing again.
  • 55 Answers
Might have a clogged fuel filter. try to drain and replace. run fresh fuel. the pulse also could come from too much fuel causing a burst in the main heat exchanger. if this heater is older than ten years i would trash it and buy a new one so you dont blow up
Posted on Sep 13, 2009
100,000 btu reddy heater runs but smokes alot and you can smell raw fuel what's wrong
It sounds like the fuel is contaminated,if it is not k 1 kerosene ,or grade A diesel fuel,this could be the problem,clean the tank,and start with a k 1 kerosene,and see if it clears up,then go back to the grade A diesel fuel,if this does not work,replace the filter in the tank,and check the intake air filter,make sure it is not cloded up,or behind the filter,last thing ,only after checking and doing all of this,the pump pressure may need adjusting,but do not try this with out a pressure gauge,and a manual .You can break the pump easy.I have a manual for the ready heater,just let me no if you need it,please rate,thank yopu,> roniecon@gmail.com
Jan 05, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Propane 100,000btu heater runs fine but has a lot of fumes, it almost burns your eyes
Go to my tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters for all your answers. Your air fuel mixture is off. You need a new air filter and need to set the bleed air. For that you need special tools which you can get at the information I give at my tip. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 13, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Do i need to replace filter if i have been using kerosene and want to switch to diesel
No, the kerosene is number 1 fuel oil and Diesel is number 2. No.2 is a heavier fuel with more BTU's than the kerosene. After you have burned the diesel for awhile, you may want to change the filter. If you have trouble getting the diesel to burn, mix it with 25% kerosene and it will flow and go through the nozzle easier
Jan 04, 2010 | Reddy Heater 60,000 BTU Kerosene...
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Diesel
you can run a premium diesel but it does tend to burn dirtyer than K1 kerosene.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Burning eyes, can't breathe.
These produce large amounts of carbon monoxide, so you essentially are poisoning yourself. Leave the garage door open part way when using it.
Feb 10, 2008 | Reddy Heater RLP100 Portable Forced Air...
Ready heater 100,000 btu won't fire up!!!!!!!
go to www dot desatech dot com. you should be able to find what you're looking for here.
Jan 13, 2008 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput Logo
125 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
