Question about Whirlpool LGB6300 Gas Dryer
Whirlpool WGD5500SQ0- will not heat up
My Whirlpool WGD5500SQ0 will not heat up. It is running, but does not dry.
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
    Problem Solver:
  • 11 Answers
This is a gas dryer. Check the venting for any restrictions or and outside blocked damper. This would cause cycling of the hi-limit thermostat and the gas burner would cycle off and on. Thus, minimal heat.
If they are ok, then suspect either a broken igniter or weak gas coils on the gas valve.
Posted on Sep 20, 2009
Duet. Why does it run but no heat and doesn't dry clothes?
You most likely have a bad heating element.
Try this video
Jun 10, 2015 | Whirlpool Dryers
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
How do I change the thermostat
Unplug your dryer, remove the vent hose, and take the back panel off the rear of the dryer. The thermostats are located there. I'm not sure which one you want to change, but you can test them one at a time by unhooking one lead on each one and checking for continuity. If you run across and open one, then that's the bad one. Don't forget to test out the thermal fuse, either.
However, that being said, if the thermal fuse is good, I would suspect the valve coils or the glow bar before going after a thermostat.
Oct 18, 2014 | Whirlpool Dryers
Why is my dryer not heating?
The heating controller may have failed.
Jul 28, 2014 | Whirlpool Dryers
Whirlpool model #WGD5500SQ0 heats up, then goes cold and doesn't heat up again.
Hi, You will need to change the coils on top of the gas valve. They overheat and will not open the gas valve.
Here is instructions on get to the coil.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jul 10, 2009 | Whirlpool LGB6300 Gas Dryer
Cannot remove blower from motor shaft
It does unscrew although at times they do stick. I would find a flat spot on the motor shaft and get a crescent wrench on it and lodge it so it doesn't move and then grasp the blower wheel and turn to remove.
Oct 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool dryer does not heat
check the lint hose could be cloged air need to flow through it to dry if stopped up want dry and can cause a fire
Feb 15, 2008 | Whirlpool LER8648P Electric Dryer
Whirlpool clean light flashes 7 times
Actually, the button order to put it in a diagnostic cycle and clear the blinking clean light on the gu2500 is HEATED DRY, NORMAL, HEATED DRY, NORMAL not the other way around as Iden had posted.
Mar 27, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool LGB6300 Gas Dryer Logo
794 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
