Question about KitchenAid KUDC25CH Dishwasher
Kitchenaid KUDS25SH dishwasher still leaks !!
Kitchenaid dishwasher still leaks even after I replaced all the gaskets and seals. I replaced the bottom door seal and the tub gasket/seal. The dishwasher still leaks from the bottom of the door. Should I try putting silicone on the bottom door seal?
Krazytech
  • 725 Answers
SOURCE: I have a Kitchenaid KUDS25SHBL1
Have you removed the outer door to check if the leak is coming from inside the door . also check the bottom door seal ? also check the around the soap dispenser as I have had to silicone around them to keep them from leaking before..let me know if this helps at all.
Posted on May 11, 2008
SOURCE: leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Posted on Nov 11, 2008
skrbin
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
SOURCE: KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Posted on Mar 30, 2009
SOURCE: door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Posted on Jul 02, 2009
Kitchenaid dishwasher door leaks out bottom middle of door when it goes into drain mode?
You probably need to check the door gasket for proper sealing and maybe replace it if the dishwasher has been in use for awhile
Oct 13, 2012 | KitchenAid KUDI24SE Built-in Dishwasher
When washing, water is leaking from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
eahgdajshgf
Sep 25, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher leaks after it fills up and starts to wash
Make sure the dishwasher is level. If the water is leaking from the door, you should replace the door gasket.
Water under the dishwasher could be from a leaking hose or loose hose connection. Check these by removing the bottom front panel.
The pump seal may need to be replaced. If you are not real handy, call a repairman for this replacement.
Sep 19, 2010 | KitchenAid Dishwashers
Kitchenaid dishwasher model# KUDM24SEWH5
Leaking Dishwasher
heatman101
qqqr
Apr 18, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Leaking from bottom of kitchenaid dishwasher kuds25sh builtin
Leaking Dishwasher
heatman101
zxnxz
Apr 07, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Water leaking from bottom of door
Leaking Dishwasher
heatman101
uiopety
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Oct 22, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Water leaking from front
I had the same problem. Repairman replaced flat gasket on the sump cover. Also replaced lower arm and that helped too.
Jan 02, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Open Questions:
See all KitchenAid KUDC25CH Dishwasher Questions
KitchenAid KUDC25CH Dishwasher Logo
102 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
