Question about Frigidaire Dishwashers
Hi, We have a Frigidaire dishwasher machine 1500 series with fully electronic control. It is a new unit, has been installed nearly 4 months ago. The other day, when I went to take the dishes out of it, I notice that the rubber gasket that seals the door had come off somehow. Along with it I saw, sitting on the bottom, two pieces that looked like part of the seal, but I didn't know where they came from. I put the rubber gasket back on, but now the pieces and now the dishwasher will leak when running. Does anybody know where exactly these "pieces" go? You can see a picture of them here: Sorry, I'm not sure what their proper name is.
SOURCE: dishwasher leaking around the bottom of the door
We just had the very same problem and sure enough a flexible cutting board was over the outlet...very strange but thanks
Posted on Mar 12, 2008
SOURCE: leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Posted on Nov 11, 2008
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
  • 102 Answers
SOURCE: My frigidaire dishwasher leaks from the bottom
One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it to leak out of the front and sometimes not to drain all water out. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem. Also could have a bad door seal. Check for any tares in the gasket.
Posted on Apr 11, 2009
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
Frigidaire Gallery Series Dishwasher - unit stops near the final rinse cycle without draining - "ER" on front display, all led indicators on front display also lit (e.g. low rinse agent, etc.),...
the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes.
it can also be the new electronic module.
If the electronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Apr 03, 2008 | Dishwashers
Frigidaire gallery stove
Hello mnwpictures - Based on the symptoms you are describing the range may either have a faulty EOC (electronic oven control) or a potential wiring failure. Try resetting the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. Does the control panel have a display? If the issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
May 12, 2013 | Frigidaire Professional Series 24 in....
My Frigidaire dishwasher will not start. It was working fine about a month ago. The lights on the panel are working and I had the water line checked and it is o.k. I cannot find a serial number but the...
My Frigidaire 500, 1100, 1400, 1500 & 2400 Series Dishwasher was purchased a month ago and it will not start either. The 8 second lock under "Heat Dry" is lit, but nothing happens when you press any of the other buttons. Any ideas?
Mar 27, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Hi, m'y dishwasher do not fully drain after is cycle, look like the installation is good and the glass filter is clean (Buyed new in june)
make sure your dishwasher was installed level side to side and front to back check it with a torpeto level (that`s a small level about a foot long ) if it`s not level there are leveling feet on all 4 corners screw them up or down to get level
Oct 08, 2009 | Frigidaire FDB1502RGC Built-in Dishwasher
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire gallery series FDB125ORES1 wash light blinking, dishwasher won't cycle on.
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Aug 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
