Question about Samsung CLP 315 Laser Printer
All 4 toner lights flash after power up
I have not used the printer for a few months. Now I am setting it up the printer and after powerup of the printer, the standby light is solid green but the 4 toner lights are flashing . I have no problem printing. I have removed the cartridges and replaced them again and repowered the printer but the lights still flash. The config reports says that I have about 7-9% remaining in each of the cartridges. What does the flashing lights mean?
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    After starting Zebra S400 the printer makes an automatic calibration each time, spending 2 blanc labels on it. How do you turn off auto-calibration? Already tried the Zebra.com official site, without luck.
    SET/UP EXIT
    Hit the "+" quite a few times until you get to "MEDIA POWERUP"
    Hit SELECT
    Use the +/- keys to enter the password (1234)
    Hit SELECT - you should see a small - and + button on the screen on either side of MEDIA POWERUP (if not, repeat previous steps)
    Hit the + sign until you get to NO MOTION
    Hit SELECT to exit MEDIA POWERUP
    Hit the + button to go to the next item HEAD CLOSE
    Hit SET/UP EXIT to save changes (permanently)
    Open and close the printhead to check to see if it worked!!!
    Sep 20, 2010 | Zebra Stripe S400 Label Printer
    Brother HL-2140 Error light is flashing
    Try to unplug the power from the print, wait 1 minute then plug back in.
    This may remove the error.
    Sep 26, 2009 | Brother HL 2140 Laser Printer
    Toner light flashing althougth I have changed the toner and was shaking it before I inserted it..
    Toner should be carefully inserted into the Place where it resides.
    Improper installation makes this light flashing.
    Stpes to be done :
    01. Remove the toner gently from the toner drive.
    02. Shut down PC and the Dell Printer.
    03. Re boot the machine and the Dell Printer.
    04. Ensure Power and network cable is installed properly.
    05. Use only genuine and Dell Authorized toners in the Printer. Clean the place with nice white cloth with cleaning liquid.
    06. Now you can take a test print out.
    07. Still the problem persists, please call Printer Service engineer to solve the issue.
    Jul 21, 2009 | Dell 1710n Laser Printer
    Flashing triangular light with the exclamation mark inside it.
    Clear the printer queue on the computer (double-click the printer icon in the tray or in the Printers and Faxes folder and cancel all documents listed). Then power off the printer and disconnect the power - remove the paper from the paper tray until you have the printer memory cleared as to not waste paper.
    Jan 22, 2009 | HP LaserJet 1320 Printer
    Magicolor 2400W error
    This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
    Jan 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
    "Cannot Adjust Fusing Unit"
    Hi there set the transfer belt into the home position then power on this resets the transfer home which then allows calibration. Tray this if not replace transfer unit.
    Thanks J
    Mar 19, 2008 | Ricoh Aficio AP3800C Laser Printer
    Samsung CLP 315 Laser Printer Logo
    164 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
