Question about HP Photosmart C6180 All-In-One InkJet Printer
HP Photosmart C6180 is printing garbage with on light blinking. Keeps printing pages until tray is empty.
SOURCE: HP Photosmart C6180 won't print
HP C6180
won't make a Document copy...because it won't print in black ...will print in color any time from PC.
rebooted...won't print black in alignment or cleaning modes.
Any ideas?
Posted on Jul 14, 2008
dominusnex
  • 15 Answers
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Posted on Dec 14, 2008
MUKHTAR
  • 2017 Answers
SOURCE: HP Photosmart C6180 Ink System Failure Message
just follow this steps may help you out otherwise you need to change it.
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues,then you can go for repair or buy a new one .but i advise you to dont go for repairing bcoz it is 3 year old .
Have a nice day and do not forget to rate please...!
Posted on Feb 02, 2010
  • 1218 Answers
SOURCE: Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
Posted on Aug 23, 2010
  • 100 Answers
SOURCE: hp photosmart c6180 all-in-one keeps
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the printer was having. A similar fix may apply to other printers. 859f1d1.jpg
Posted on Sep 26, 2010
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
Can i print magnets on my hp photosmart C6180?
Your printer HP Photosmart C6180 cannot read Films or magnetic tapes etc.
Regards,
Suhail
May 17, 2012 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart c7280 blinking
Which lights are blinking? If its related with cartridges.. replace them, if its related with print heads.. replace indicated one..,
Jan 30, 2012 | HP Photosmart C6180 All-In-One InkJet...
Can you print a configuration page on this device. I need the meter reads/volumes.
Hi, you can print a configuration page from the C6180 by following these steps:
- Press the Setup button on the printer's operation panel
- Using the down arrow button, scroll down until you see Network, then press OK.
- Scroll down again until you see View Network Settings, then press OK.
- Scroll down until you see Print Network Configuration Page, then press OK.
To view configuration page instructions and ways to view page counts on other printers, copiers, and fax machines, visit the How to Print Configuration Pages blog.
Feb 25, 2011 | HP Photosmart C6180 All-In-One InkJet...
It does everything but print. Instead of printing it just keeps pumping out paper until the tray is emply.
To resolve this issue please perform a semi full reset on the unit
Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
If issue persists then print a self test page on the unit and check ink levels. If cartridges are low or empty then replace cartridges.
Oct 12, 2009 | HP Photosmart C6180 All-In-One InkJet...
When I try to print with HP Photosmart, I get
Hey Cathy,
One of my clients had this problem as well. It is due to your sensors not working correctly. In the tray there are two clips that hold the paper tight, keep trying to adjust those clips and this should solve your issue. However, if this does not solve your issue - you most likely have a hardware issue and parts will need to be replaced.
Jul 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 responds to print but puts out blank pages
All I had to do was clean the print head. Try these steps: Press setup, scroll down to tools. Select clean printer head. The printer will run a clean cycle and then print out a diagnostic test page.
Jun 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180
load the paper in the tray
go to file menu then page setup.
select HP all-in-one printer
choose the paper size, orientation and scale percentage
chick ok then choose print from the file menu
configure the print settings suited for your project.
click print
make sure that you choose the correct paper type before you click print.
Nov 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
