Question about Garden
John deere l11 weak battery had to jump off the last 4 or 5 times and this time hook up jumper cables and turn the key and get nothing. no lights no click just nothing. tried 2 sets of cables
  • 2,841 Answers
Remove the old battery and clean the cables and battery posts. Hook a battery charger to it and fully charge the battery. If it will not hold a charge or the problem continues, replace the battery as it has shorted or dead cell. After replacing the battery or if the battery appears good and then runs down suspect the alternator is bad. Check the voltage at the battery with the engine running. You should have at least 13.5 volts on a 12 volt system and 7.5 volts on a 6 volt system.
Posted on Sep 12, 2009
Starter problems, Suggestions???
Starters tend to fail intermittently. Yes, if it started after a "whack", I woul suggest replacing your starter. Make sure all connections are tight and of course clean terminals and cables.
Sep 03, 2016 | Cars & Trucks
How to check starter system on a John Deere 2355 tractor
Weak battery / Loose or corroded cable to battery or starter . If you can get to starter posts with jumper cable try to jump it if it trurns
over the starter is not the problem. Check all connections as a first step this sounds like a bad connection or weak battery.
Aug 18, 2014 | Garden
Starter won't stop
Sound like your starter solenoid may have got damaged. Jump the solenoid connection to the large starter connection to see if you may have a fault in the ignition.
Jan 04, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deer mower
Possibly just the fuse. But if you say the jumpers WERE positive to positive and neg to neg it shouldnt have been a problem but maybe the pos clamp touched the body. That would have cooked the battery. First check the fuse, if thats ok then connect your neg jumper lead to the chassis of mower to neg of truck and the pos to pos of truck and hold the other end to the large terminal on starter motor.This will bypass everything and only test starter. Engine will spin over if starter motor ok. There will be a strong spark when touching terminal so watch for fire hazard.
Jan 30, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Model 870 will not start. A new battery has been installed and there is power to the lights but noting appears to get to the starter .
Check your starter solenoid. Find it by following the pos. battery cable back to it, using jumper cable jump acrossed to other big cable on the other side of solenoid. With key in on position it should run. If it does eigther solenoid is bad, or ign swithc or the connections are dirty.
Oct 02, 2010 | John Deere &Reg Branded 27" Tractor Metal...
I have telstar tx5 ghia 1990 2,2l 4 cilind automatic, power everithing,car is done 240000.yus wont start one mornig doing klik didn t start and couple time kliking alnaser (starter) and i have used cable ...
Hi
Easiest test is to reconnect jumper cables and switch lights on, if these work and no noise AT ALL from starter, NO clicking at all then could be the jumper cables are too light like most are. Try 2 sets of jumper cables. Ensure that the cables are correclty applied, Red to Red and the black is the last connection to a good steel part on your engine, NOT the battery.Always ensure the car being used to jump from is running at all times while cables are connected.When it starts remove this one FIRST also.
Cheers cbacer
Apr 30, 2009 | Mazda 626 Cars & Trucks
2000 beetle battery
Hi
Sounds like your battery, have you had it heavy discharge tested ?
Get the alternator charging rate tested if battery tests OK.
Good Luck !
Please give a FixYa rating !
John.
Feb 04, 2009 | 2000 Volkswagen Beetle
Garden Logo
216 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
