Question about KitchenAid Dishwashers
Our dishwasher doesn't turn on--no power. I have
Our dishwasher doesn't turn on--no power. I have checked the circuit breaker--fine. The disposal is on the same plug and it works. Is there a fuse in the dishwasher?
  • 33 Answers
There is sometimes a switch mext to the disposall that switches the dishwasher on & off. if no luck revers the 2 plugs just to see if it will come on if not then check that the plug is hooked up under the front of the dishwasher behind the cover at the bottem.
Posted on Sep 13, 2009
The machine does not turn on;does not seem to hve any power. this started when the garbage disposal broek down...any connection?
Check for circuit breaker being tripped. Quite often the breaker protects both pieces of equipment. The Breaker handle will be positioned between "on" and "off". Push the handle to off, there will be resistance, but push it all the way to off, then push it to "on". You may find this also fixes the disposal problem as well.
Nov 29, 2015 | Samsung DW7933LRABB
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
Dishwasher LD-1420T1 tripping power in the house?
Okay, this could be tricky because depending on who installed it, they might have wired into it. Check your garbage disposal and if you have anything else plugged in nearby, check that wiring too. Some installers have a nasty issue when it comes to hard wiring. They don't like doing it. So instead of hard-wiring your garbage disposal, they'll cut it in to your dishwasher. If your garbage disposal or anything else is wired to your dishwasher the load on the washer and the current the washer is using is too high. That's going to trip your breakers. You should probably contact an electrician and have them check the breaker box to make sure it's wired correctly. You may need to upgrade the breaker or have the dishwasher circuit upgraded. If it's an old house, it could be anything but first, check to see that nothing is wired into your dishwasher. You can tell if you have a few switches in the same outlet and turn them off. If your garbage disposal won't work and the DW won't either, then you have a wiring issue. That's the easiest way to start.
Apr 06, 2014 | LG LD-1420T1 Dishwasher
No power or signs of power
check the power going to the machined,
check the fuse or circuit breaker.
check selector switch or pushbutton switch.
Jun 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I just installed the dishwasher and do not turn on
On the LG LDF6810 model, you should be able to open the door and press the power button (right side of the top of the door.) It should wake up and you should see lights.
If that fails to happen, trace the power from under the dishwasher to where it is plugged in to the wall. If it is under the sink and you have a waste disposal, it is very possible that both outlets are switched on/off by the disposal switch. I would find a known-good table light or something similar and plug it in to the outlet and see if the light turns on when I switch it on. Electrician is needed to separate the top/bottom outlets so the dishwasher is always on and the disposal is properly switched.
If the dishwasher is not connected to an outlet, rather directly connected via electrical wire, have an electrician confirm the hot, neutral and ground wires are properly connected under the dishwasher and check the circuit breaker/fuse for that circuit.
Please report back what you find, OK?
May 20, 2010 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher not working after power outage
Occasionally there is an isolated GFCI circuit for the dishwasher. If you can validated with a voltage meter that the unit is actually getting power.
I used to always install an isolated GFCI circuit for each: microwave, dishwasher, refrigerator, and garbage disposal.
So that is what i would check first
Mar 14, 2010 | GE Dishwashers
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
No power is there a reset button?
Check your circuit breaker or fuse box.
Also, check under the sink. Some models plug in and some are wired in. The plug might have been knocked out. Also, someone may have plugged it into the disposal plug. Try turning the switch on for the disposal and see if the dishwasher comes on.
No, there is not a reset button on a diskwasher.
Are you sure you have no power to the dishwasher?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Roper RUD3000H Dishwasher
BADGER GARBAGE DISPOSAL NO POWER
Have you checked the circuit breaker on the disposal itself? In the bottom there's a little button that resets the circuit breaker. press it in and see if that works. If the disposal is still jammed you should hear a hum.
Dec 28, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
JDB3610AWX - Controls (pushpad) does not respond to input (doesn't turn on, led doesn't light)
in the manual there is a sequence to unlock the control check the manual for the unlock sequence
Apr 25, 2008 | Jenn-Air JDB3610 Built-in Dishwasher
Dishwashers Logo
80 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
