Question about Philips 50P8341 50" Rear Projection Television
I am having a hard time adjusting the color and focus on my Phillips 50p8341. Can you help?
  • Philips Master
  • 3,459 Answers
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Sep 13, 2009
Why does the tv look have a red tint all the time
The CRT coolant is needing replacement in the blue and green CRTs which make the red dominate. You can see the coolant is bad by looking in all three lenses you will see that the red is clear and bright where as the blue and green will be hard to see through which makes the colors dim. Replace the coolant should solve the issue. You can get the Phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for all three CRTs and the CD with instructions.
Mar 08, 2011 | Philips 50P8341 50" Rear Projection...
Picture is not clear. Has a green tint and glow.
Repalce the coolant in the CRTs. You can get the Phillips CRT coolant replacement kit at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Oct 13, 2009 | Philips 50P8341 50" Rear Projection...
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Picture seems to be losing its sharpness and colors bleed
most likely scenario is that the coolant in the CRTs need replacement very common problem with phillips magnavox TVs, The picture will get hard to focus and the color will lose its intensity. You can get a coolant replacement kit for phillips at the following link under the repair kit category. The kit contains all the coolant needed and a CD with step by step instructions on how to do the repair. Heres the link.
http://servicemanuals.vstore.ca/
Feb 08, 2009 | Philips 55PP9401 55" Rear Projection...
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
My Phillips 50P8341 50 inch has color adjustment problems, any suggestions?
http://www.usersmanualguide.com/philips/tv__projection_tv/50p8341
go to this link and download Owner's / User's manual
Dec 13, 2008 | Philips 50P8341 50" Rear Projection...
Blue screen with sound but nothing else!
I, too, acquired a Phillips without a manual and was experiencing a similar problem. My model is PTV 916, but if your TV has a "source select" button, say a prayer and press the button. From that point, I don't know what else I did, but I do get TV programs now.
Jan 04, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
201 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
