Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425
Kenmore 13.7 Frost Free Freezer
We just purchase a new Kenmore small freezer. When the blower runs it is very noisy like air running thru a tube. Is this normal? It seems excessive, it can be heard thruout the house. We also have a frost free Kenmore refrigerator purchased a few years ago and it is a lot quiter. The blower comes on at least 4-5 times a day also. Is that normal for these.
Thanks,
  • 40 Answers
You may want to check the compressor area of the unit.There may be something on the coil or fan blade.(Packing foam,paper, etc)
Posted on Dec 14, 2007
My Kenmore freezer is continuously running. It
clean all of the door seals and all of the contact point with freezer
Jul 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Where is the drain tube for the water being taken out of the freezer? If it's clogged, can I clean it?Kenmore upright frost-free freezer.
behind the panel below the evaperator, use some flexible curtain wire or electrical wire to clean the tube out. Hope this helps :)
Jun 24, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Mar 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
The thermostat is out on my Kenmore 14.8 cu ft freezer
I asked a local repair shop. Just pull ******* the sensor wire and it will slip out of the tube through which it runs. Run the new wire which is attached to the new thermostat thru the same tube. Prior to purchasing the thermostat, I tested with a ohm meter for continuity ( there was none) and jumped the attaching power wires. The compressor ran verifying the problem with the thermostat. Thermostat cost $47.00.
Jun 07, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425 Logo
250 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
