Question about Lexmark X5470 All-In-One InkJet Printer
Scanning using the 5550/6000 serries machine
Can't get the printer (5500/6000 serries) to scan document.
SOURCE: scanning
Many issues are caused when the HP All-in-One is connected to the computer using a USB cable before the HP All-in-One software is installed on the computer. If you connected the HP All-in-One to your computer before the software installation screen prompts you to do so, you must follow these steps: Troubleshooting common setup issues 1. Disconnect the USB cable from the computer. 2. Uninstall the software (if you have already installed it). 3. Restart your computer. 4. Turn off the HP All-in-One, wait one minute, then restart it. 5. Reinstall the HP All-in-One software. CAUTION: Do not connect the USB cable to the computer until prompted by the software installation screen.
Posted on Aug 19, 2007
SOURCE: scanning document leaves streak down right hand side
Backu
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Rowboat
Posted on Dec 26, 2007
  • 48 Answers
SOURCE: SCANNING
Load the text document face down on the scanner glass.
Open the Lexmark Imaging Studio.
Click the Scan & Edit Text (OCR) button (shown below).
The All-In-One Center appears with the Scanning & Copying tab expanded.Click Preview Now in the upper right corner of the All-In-One Center. An image of the scanned document appears in the preview section.
Click and drag the box with the dotted lines to select a specific area of the preview image to scan.From the Select your text editor: drop-down menu, select a word-processing or text-editing program.Click Send Now.
Posted on Jun 18, 2008
SOURCE: HP Printer - Scanning Documents
i had the same problem with vista home premium. vista does not support one touch scanning (pressing the scan button on the printer). to use scanner with vista home os use the paint application and start scanning with the file section. step by step:
start (windows) icon lower left tool bar
programs
accessories
paint
file
from scanner or camera
the hp should start working - note: i sent a short cut to the desk top for the paint program for future use
Posted on Feb 04, 2009
  • 1602 Answers
SOURCE: scanning
CHECK THE FOLLOWING FOLDER INTHE CONTROL PANAL;
DEVICE MANAGE[GREEN MARKS OKAY ANYOTHERS BAD, CLICK ON THEM.]
NETWORKING AND SHARING SAME AS ABOVE.
PROBLEM AND REPARTS, SERICUTY AND SYNC CENTER.
ANTI VIRUS AND FIREWALL MAYBE CAUSING ALOT OF YOU ISSUES
ROD
Posted on Feb 09, 2009
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
Lexmark Pro901 When scanning from document feed the machine seems to scan only a part of the page whilst cutting out the information at the bottom of the page.
Make sure to set the correct paper size when scanning from the ADF. If you're scanning a legal size document, set the paper size to legal.
If it doesn't work, try to reset the printer back to its factory settings:
1 From the home screen, touch Setup (wrench icon), and then touch Use Factory Defaults.
2 Touch Yes.
3 When prompted to set the initial settings of your printer, make your selections using the touch screen.
Oct 12, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
How can I email a document from xerox copy machine through my laptopp
The best way to email any document from any printer is to have a scanning program that can scan from your printer/scan/copy machine. If your printer only has printing capabilites then it is impossible to capture the printed document back to your laptop.
The first step is to check to see if your Xerox copy machine is a model that includes printing/scanning/copying capabilites.
If it does, then install the scanning program.
Once installed, scan your document, save it to a place you remember on you laptop, then email it using your favorite email program, such as hotmail or yahoo.
hope this helps, if not let me know.
Feb 12, 2012 | Dell Computers & Internet
My kodak 5500 all in one inkjet printer will send fax, but comes thru blank at the other end. Yes I have the document with lettering up like it says.
The problem, more than likely, is the quality of the scan. The 5500 sometimes overexposes the original. Test the scanner by scanning the document tou want to fax using HomeCenter software and looking at the screen preview. You can make some pre scan image density adjustments by changing the fax settings brightness setting to low (1 or 2) and changing the color setting.
Apr 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Scanning to PC
hi,
try using the kodak aio home center
it is much easier and gives you more conrtol, including editing
dont scan directly from the scanner
Feb 11, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Scanning
u can scan it as a document and just adjust the settings from the computer to scan it in as colored document
Jul 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Can't get scanner to scan
Install the software from the CD included in the box.
Be sure to follow instructions for setting up and connecting to your computer, and use the Kodak AiO Home Center software to setup and manage the details of your scans, depending on whether you are scanning pictures or documents, color or black and white, etc.
The User Guide is available at the Kodak web site, if you misplaced yours:
http://www.kodak.com/global/en/service/products/ekn033541.jhtml?pq-path=10623
Jun 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
