Question about Dell Latitude D600 Notebook
Toshiba Satellite L3505D-S5938 Intermittant Keyboard Issue
Selected keys don't work on my laptop keyboard:
0 )
top P
space bar
I first had the keyboard replace, and that fixed the issue for about one day.
I checked my keyboard drivers, and Windows tells me they are up to date.
I tried uninstalling the keyboard drivers, and often that would fix the issue for about an hour, but after several attempts, that doesn't have the same results currently.
I am using Windows Vista.
Any ideas?
  • Tim Sep 12, 2009
    I have macafee installed and running.
    Problem Solver:
  • 15 Answers
I'm not quite certain about ur problem but something like that happened me. i found out was that by pressing the FN Key and F10 on my Satellite it lock out certain keys on the keyboard and the others did something else. mighten work but worth a try. u might have a different problem to me.
Posted on Sep 13, 2009
    President:
  • 1,462 Answers
Hi, This is beacuse of Virus/trojan that blocks the function o certain keys,
Try scanning your system with good antivirus, this would solve your problem permanently
RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 12, 2009
Why/is/my/space/bar/and/shift/not/working/cannot/enter/question/mark/either
Keyboards are devices that can fail as easily as any other part of the machine. Even more so since there is the human intervention (finger) factor. The space bar is a heavily used key.....the SHIFT and question mark - not so much. You probably just need to replace the keyboard in the device.
Sep 07, 2016 | Toshiba Computers & Internet
Sign in on toshiba moves to start but arrow disappears so it wont work
If the cursor highlight is positioned over the START button (icon) then you can select it by pressing ENTER or SPACE bar, which is the keyboard equivalent of double clicking with the mouse. To move between the fields, press the TAB key (shift TAB to go backwards or to the previously selected field).
However, the question is not clearly stated...
Jun 09, 2014 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite.C655.enable.space.bar
Hook a external keyboard, if okay! problem with the laptop keyboard. Try a system restore and bring the computer back to a earlier time before this happened, just might work. The keyboard can be disabled from the bios setting I don't see how it can be done any other way.
Mar 17, 2012 | Toshiba Satellite C655-S5140 Notebook
When i am typing , the keys are automatic got a space even i didn't using the space bar .
Hi Friend, In this case i would recommend you to please try connecting the external keyboard to the system and check if you have the same issue with the external one as well.
If the external one works fine then I believe there is a need to reseat ( disconnect and reconnect) the keyboard.
Dec 09, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Keyboard problem with space bar
Is it stuck ... i.e. many space being keyed ... when you are not holding it down ? or is it NOT giving you a space when you press on it ?
Either way, try using a different (external) keyboard to see if the same problem exists. If it's the keyboard, have it cleaned/serviced.
Aug 11, 2010 | Toshiba Satellite Pro M30 Notebook
TOSHIBA SATELLITE 205-6267 AND MY ALT KEY NOT WORKING
You should have two (2) "alt" on your keyboard. So if one does not work you can use the other.
The two alts are at right and left side of the space bar.
You also have the option of using an external keyboard through your usb.
Take care.
Jan 02, 2010 | Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
I have a Toshiba satellite notebook.Keyboard problem
You can use a standard USB desktop keyboard or a mini laptop usb keyboard or just replace the keyboard with one you can buy on Ebay.com
Oct 09, 2009 | Computers & Internet
Can't/use/my/spacebar/ don/'t/have/recovery/cds/for/satellite/135/using/vista
I'm afraid that your recovery CD's won't help you get the space bar working.
There could well be dust, biscuit crumbs, hairs etc that's preventing the spacebar from working, turn the laptop off but don't close the lid, stand the laptop on it's side and get yourself a clean, dry paintbrush.
Start to brush the keys and gently tap the keyboard with the other end of the brush to knock out any foreign objects that could be trapped under the spacebar.
Once your happy it's clean turn the laptop on and see if the spacebar works.
If you still have the same symptoms then the keyboard will have to be replaced.
You can use the on-screen keyboard to substitute for the spacebar for the time being.
Good luck.
Aug 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Keyboard space bar
turn your keyboard upside down and tap it a few times. if that doesnt solve the problem repeat.
If it still won't work write back for more ideas.
good luck and please rate my answer. thanks.
Feb 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Dell Latitude D600 Notebook Logo
194 people viewed this question
Alun Cox
