Question about Viper Security and Remote Start System (basic install included)
Viper 5901 Starting issues
Viper 5901 alarm/remote start on 2006 F-350 Lariat Diesel. Remote will start truck fine but shuts off after about 15secs. Truck will start a couple seconds later and shut off again in about 15secs. Cyle continues....
Also shock sensor does not seem to work at all. I can load/unload ATV in back of truck without setting the alarm off? Any way to adjust the sensitivity?
  • 22 Answers
My 1997 F350 PowerStroke would cycle on and off also.
I found out the problem was my glow plugs heating up also drained my battery. Diesels take a few seconds to start reading 12v or more because of the high demand of heating the glow plugs (wait to start).But the culprit was my giant *** amplifier was also charging up its capacitors,upon start up. So my "Diesel Alternator delay" was extended.I cured the problem by shutting off the Stereo
(which also shuts down the Amp) before turning off the Vechicle.
As long as my stereo is NOT on when I AutoStart my truck there are no problems, even my heater can be on, just not my High Current Drawing Amp.
Posted on Jan 23, 2010
I need to adjust the time that it waits to start for my glow plugs in my 2001 ford excursion diesel 7.3. I need it to wait another 10 - 12 sec.
Posted on Jan 07, 2010
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Cant start car with key
It sounds like you might be having an issue with the transponder or "chip" in that key. When you turn the key and it doesn't start you probably see a flashing key icon on the dash with a circle and a line through it. When you remote start the car it is using a by pass module to trick the car into thinking you have a valid transponder key in the ignition when it starts up. Go to a locksmith and have another key cut and programmed to the car.
Jan 29, 2014 | 5901 Security Remote Start System
The Responder LC remote for my Viper 5901 will not charge. What can do I do to fix this? I have only had this system for less than 2 months.
Plug the charger into an outlet. Plug the charger into the remote, unplug the charger from the remote. Repeat until "charge" appears on screen of the remote. You may have to repeat the process approximately five times until charge appears. There was an issue with the batteries in the remotes having to be reset. If this does "fix" the issue, your problem may be with the charger itself. You can use any usb charger to charge the remote, i.e. phone car charger, computer, etc.
Feb 02, 2011 | Viper 5901 Security Remote Start System
I have a viper 5901 installed on my 2008 Impala SS and every now and then the alarm goes off saying the doors are open but they are closed. why would this happen
This is happening because they used the cars domelight to set the alarm off when the doors are opened. When the cars computer goes into battery save mode and shuts down certain parts of the car, the domelight is one of them and a slight ground or 12 volt positive is backfed to the alarm and sets it off. This usually happens after 30 minutes. they should take the alarms door trigger and actually go to the cars door latch wires. The colors are:
gray/black - driver door tan/white - pass door lt. blue/black - back driver door lt. green/black - passenger back door
Aug 31, 2010 | 5901 Security Remote Start System
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Installation of a Viper 5901 remote start into a 2001 Ford Explorer Sport
viper 5901 remote start alam installing it on a 1997 ford explore i need a detail wiring diagram
Mar 04, 2009 | XX-67A II LED/Valet Switch Pod
Remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
Jan 14, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
990 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
