Printing a contact sheet
How do i remove the name of the image when printing a contact sheet so it just prints the images without the text underneath each please?
How do I print onto cd?
Please follow these steps:
1.
Turn your printer on. Most power buttons are located on the top of the printer. Press and hold down the button until its LED light turns green.
2.
Choose the image or text you desire to print onto the CD. On your computer, open the image or text you desire to print. images should be opened by clicking on your computer's "Start" icon and selecting the "Pictures" tab folder within the Start menu. When the Pictures folder opens, click on the image you desire to print onto the CD to enlarge it. If you are planning to print text onto the CD, open the text in Microsoft Word or any other desktop publishing program you may have on your computer.
3.
Insert the CD into the printer. Press the "Eject" button that can be found on your CD printing enabled printer. A CD tray will open automatically. Place the CD into the tray print side up. Close the CD tray. The printer will begin working to detect the CD. Once the CD is detected, your printer's LED light will either flash green or another indication color.
4.
Print the image or text onto the CD. For image printing, click on the enlarged image's tab that will be on your computer's taskbar. You will see a horizontal row of action icons below the image. Click on the thumbnail image of a printer to print the image onto the disc. For text printing, simply click on the "File" action on the navigation menu in your desktop publishing document. Click "Print" within the "File" drop down menu. The image or text will be sent to the printer once you choose the "Print" action.
5 .
Remove the CD from the printing tray. The CD will be fed through the printer during the printing process. Once the process is complete, the CD will come through the bottom of the printing tray. Take the CD from the tray when it reaches the bottom.
The above mentioned steps must help you. In case of any difficulty please revert back.
Apr 08, 2011 | Canon PIXMA iP5300 InkJet Photo Printer
Why are setting index print
Index print or contact sheet is an image that traditionally contains the negative images of an entire roll of film, so I do not understand the context with speakers. Please clarify.
Dec 03, 2010 | Creative Labs SBS 370 Computer Speakers
I need to print a mirror image
Do you want to print in Mirror Image ?
Follow the steps and you will be able to do so,
Click on Start button
Open Control Panel
Open Printers
Highlight the Printer icon name ( HP Photosmart C4680 All-in-One Series )
Right click on the Printer icon and Left click on Printing Properties
Under Advanced Tab click Mirror Image ON
Click Apply - Click OK
Try to print and it will print in Mirror Image.
Thank you for contacting Fixya
*Please rate this solution with thumbs up
Nov 20, 2010 | HP C4680 All-In-One Inkjet Printer
Print - Generic Text/Only We didn't find the driver for the Olivetti PR 4RT for windos vista and now we are configuring the driver Generic Text / Only but we don't know how to print images, can you...
Please double check your model name and number on your printer. I have checked and do not find anything under PR 4RT. There are several other models which have available drivers, but this model is not found.
I look forward to hearing back from you.
Brian
Feb 18, 2010 | Office Equipment & Supplies
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Hp laserjet 2600n
Overview Though it's priced for the home-office budget, the HP Color LaserJet 2600n performs like a printer in a higher cost category. The result: powerful, networkable printing-plus high-impact, professional documents and marketing materials-without breaking the bank. Includes black, cyan, yellow, and magenta print cartridges.
  • Save space with the compact design that you can put anywhere, even on your desk
  • Give your brochures and flyers a competitive edge with HP's image-enhancing ImageREt 2400 color technology
  • Spend less time waiting around for documents; the first page prints in less than 20 seconds, even when the printer has been in Sleep mode
  • Process complex documents that have text, images and graphics with the powerful 264MHz processor and 16MB memory
  • Monitor the print status via the convenient front panel, on-screen LCD display
  • Replenish the paper less frequently, with the optional third tray (250 sheets), which brings the capacity to a total of 500 sheets
  • Stay on top of toner replacement with HP SureSupply, which sends alerts when a cartridge is low and helps you monitor its remaining life
Aug 06, 2008 | Office Equipment & Supplies
Printing black squares in word.doc
It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
Apr 11, 2007 | HP PSC 2410 All-In-One InkJet Printer
16 people viewed this question
k24674
