I'm trying to install a cd burner but I don't have the installation disk that came with it and my computer is not reading it
  • Nike Merritt May 11, 2010
    Look up manufacturer on the web and see if they have a download for it, since you did not specify the make and model, we cannot help you until you do.
  • Jim LeVan
    Jim LeVan May 11, 2010
    what make/model burner? is it external or internal?
    Sniper:
  • 62 Answers
Download free cd burning software from the following link and install it. you will be able to burn your files.
http://www.getdata.com/download.php
Posted on Sep 12, 2009
  • 52 Answers
Make sure the jumper cables at the back of the rom are set correctly, if you are using a the same ide cable as the hard drive the rom must be set to slave. If you are using a seperate ide cable, make sure its set to master.
My hp pavillion dvd drive just hangs up when I try to reinstall windows
Is the disk your using homemade or a factory made disk? Some drives just won't read 100% of the disks inserted into them. Have you tried another installation disk to see if the problem persisits? Are you able to "SEE" the files on the disk using Windows Explorer? Can you copy those files to your hard drive? If yes, then try installing from the hard drive files instead of the disk. What OS are you trying to install?
Apr 08, 2014 | Pioneer DVR-107D DVD±RW Burner
My cd rom is not reading any disc and i keep hearing a clicking sound.
Go to
1-my computer
2-then properties
3-then device manager
4-then look for your cd-rom
5-uninstall the driver (only if you have the cd-rom installation program from the manuf.) and restart your PC
If you don,t then find any conflicts in the device manager "like a yellow symbol" and if you find any try to "update driver".
Keep posting!
Feb 22, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
SLIM portable USB2 otical drive
Hmmm sounds like corrupt install or possibly the bad drive....or the disk you are trying to read is bad
Sep 11, 2009 | Samsung External Slim DVD-W USB Compatible...
Cant install program from DVD drive GWA-4164b
do you use orginal CD or DVD. if you saying yes. your CD/DVD drive is getting break down
May 27, 2009 | Acer (4432A-002) CD-RW Burner
Combo Cd/Dvd Drive is not reading Cds nor DVDs
1. Remove your burner from your computer then open it by removing the screws under the burner.
2. When the cover has already been removed, get a cotton bud then soak it in alcohol to clean the lens. Because the lens might just be dirty. Then after that put the cover back by screwing it again then install it back to your computer.
Apr 08, 2009 | LG GMA-4082N 8X SLIM DVD RW DRIVE FOR...
First check that your system meets the minimum requirements...ie. you have at least 512mb of ram, CPU of at least 2Ghz Pentium4 or equivalent(with off-board video), and your hard drive has >4GB of free space.....can view full list at:
http://www.amazon.com/Spore-Mac/dp/B000FKBCX4
Is SPORE on a duel layer dvd? If your drive is on the older side, you might try a newer one or you can try the following:
--take out an empty flash drive with
--go to a computer that will read the disk...if you have another computer or u can use someone elses
--put the disk in their computer and if the computer is able to read the disk, then put your flash drive in the computer and copy the disk onto your flash drive...
-y-ou can now try to install the program from your flash drive instead of using the disk...
NOTE: Trying this method wont cause any damage, but if the disk is encripted or if the install software is set to check for the disk during installation, then this may not work, but is worth trying since because a) even if it doesn't work, no harm is done, and b) you wont need to replace your disk drive if it does work.
Feb 12, 2009 | Acer (4432A-002) CD-RW Burner
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Burner doesnt recognize CD's
is this a new device? were there any updates on your compter recently? if any of this is correct, you should install new drivers. if this doesnt help, and you aren't capable of dismantling the CD and check its lens, try installing the CDrom on another computer, thats the best way to determine if the problem is with the CD itself or not.
Feb 22, 2006 | Sony CRX 1611 CD-RW Burner
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
