Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer says I need color replaced
I've tried replacing with new cartrige it says that it still needs replaced
SOURCE: 5100 ink error
Both printer ligh flash red yet both cartridges are new and full.
I have removed printer head and swiched of printer for 15min as suggested by Kodak but the red light still flash.
Please can you help.
Kind Regards - Patrick
Posted on Mar 04, 2008
  • 64 Answers
SOURCE: have kodak esp3 printer said I needed to replace
I could suggest that you contact Kodak direct as you will need to get a replacement printer. Log onto www.kodak.com and select the help and support tab. Select the online chat option and tell them about this issue.
Posted on Oct 26, 2009
shockwave727
  • 262 Answers
SOURCE: Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Posted on Nov 04, 2009
rulds2008
  • 3866 Answers
SOURCE: replace color cartridge error
Okay kodak and there fine evidence for Quality will not prvide any overides for you because it viods there warranties on the unit, Thus if i provide a override I am breaking the same Terms of service you agreed to when you signed up. all I can say is search on the internet for the overide buttons : * X I even went that far to have to plead the 5th that i told you that much. Its all in the firmware hint , hint. Where, when , why and how I cannot say.
give the tech a roud of appluase
Posted on Dec 11, 2009
  • 1218 Answers
SOURCE: my printer keeps sayon my
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Dec 06, 2010
HOW DO I FIX THE INK CARTRIGES WHEN REPLACED ?
Could be improper installation, or cheap cartriges, or could be failed print head which I had and replaced with good results.
May 21, 2014 | HP Photosmart C6380 All-In-One InkJet...
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
Color prints out photos in stripes
if you are getting stripes in photos then there is a problem with cartrige, take a cotton swab and dip it in water and clean the cartridge head and then try, and if still the same problem exist replace the color cartrige.
Feb 14, 2010 | Office Equipment & Supplies
My pictures turn red
generally this is due to your ink cartrige not having enough of the cyan or yellow to produce accurate colors. that or the print heads need to be cleaned on the cartrige. you can clean them with a cotton swab and some rubbing alcohol.
if all else fails replace yoru color cartrige with a new one.
Feb 12, 2010 | Lexmark X1240 All-In-One InkJet Printer
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
HP Photosmart C5180 In Cartriges Empty
uninstall the software and reload it it will mostly fix your problem.
if still the problem presists .
feel free for further assistance.
thanks
Nov 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Faded print
IT TURNED OUT TO BE A FAULTY WORN DOWN BLACK CARTRIGE!
WE REPLACED IT,AND THE PRINTER IS WORKING FINE.
THANKS,
DURANGO21
Jul 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Wrong cartridge
Nice Printer.
First of all, see if its reading on the computer, if not, try and hold the power on the printer untill it shuts off, and then turn it back on again. Also, you might want to check the troubeshooting section if you have the manual
If none of the above works, try getting a replacement cartrige. if the connectors on the cartrige get messed up, the printer may not read the cartrige properly. Make sure the printer's connection to the cartirdge is ok too. If you know someone who has the same printer, try the "ERROR" cartrige in that printer. if it works, then your printer needs to get fixed. If it doesn't work, get a new cartrige and all should be fine. Don't get the cartrige refilled if it doesn't read in a nother printer, you need to replace the cartrige!
Jul 17, 2008 | Computers & Internet
New Black Cartrige
plz try with another cartridge
Jul 01, 2008 | HP Color LaserJet 2600n Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
