Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I HAVE GOOD PICTURE NO SOUND..SOUND WORKS IF I HOOK UP STEREO..
  • Philips Master
  • 1,210 Answers
You may have to get into the customer menu..Locate audio speakers on the menu and see internal speakers on/off....Could be this simple....But try.......On the other hand if you shorted the connections to the surround sound speakers and you would know by the howl, You audio output IC is cooked! And this is located on the small signal board. Hope for the best and expect the worst!
Posted on Sep 17, 2009
I have no picture only sound
Without more info...hard to answer. You probably have hooked something up improperly. Be sure to check cables, not just stereo cables but DVI, component, etc... to carry video signal. Good luck.
Apr 02, 2011 | Audio Players & Recorders
Connecting to a video game console
Hooking your PS2 Up To your Stereo
Just got a PS2 and trying to hook it up to your TV, stereo or both? Here are instructions to help you get everything working smoothly.
First, some basic cable definitions. These are pretty much standard for ANY system or stereo you ever get, so it's good to learn them.
RED CABLE - right channel for stereo sound (get it - Red Right?)
WHITE CABLE - left channel for stereo sound
YELLOW CABLE - video signal
Your PS2 plays games and plays DVDs. So it is generating signals that go OUT of that box. You want those signals to go IN to your TV. The most simple way to do this is to simply plug them into your TV, if you have no stereo system hooked up and nothing else attached to your TV. Most TVs have stereo left in, stereo right in, and video in. Most in fact have them all color coded with the above colors. So all you do is plug the cables in and turn the TV on. Some TVs have to be set to channel 2 or 3 to know to take the signal in from the Video In line, but your manual would tell you if that was the case. Here is a diagram of the straight connection.
I would really recommend hooking a stereo system into your TV, though. The PS2 has INCREDIBLY stereo sound and you really miss out on a lot if you just have the sound coming out of your TV speakers!! Especially if you play DVDs through your PS2, you want that sound coming out of the stereo system. So in this case you would send the video to your TV, so your TV can show the picture. You then send your audio (sound) to the stereo, so it can play the sound. Most stereo systems have multiple input spots so you can plug in your CD player, your tape player, your record player, etc. So just choose an input spot that isn't taken yet. Here's an image of that connection -
So let's say you don't have a tape player and therefore plug the red cable into "Tape Input R" and plug the white cable into "Tape Input L". To make the sound play, you would now press the "Tape" selection button on your stereo so it played the music coming through the tape channel. Since that's where your PS2 is plugged in, that is the sound that will come out of your speakers.
Jan 29, 2008 | TruTech PVS31170S1W 17 in. LCD Television
No sound, picture perfect. w3706mc. works first 6 months
Hook an external Stereo Receiver (or surround sound system) up to the Audio Out jacks on the back of the TV... this should allow you to hear the sound again.
Hope this helps.
Nov 02, 2009 | Dell W3706MC 37 in. LCD HDTV
I have hooked by two bose 161 speakers using 14 gauge speaker wire (about 8 feet) to sony str-dg720. But I get absolutely no sound from the speakers. I have hooked the speakers to port A set of input...
You gots ta isolate the problem.  Disconnect the speakers and hook them up to a stereo you know that works.  If you don't hear sound coming out of the speakers, then you know the speakers are fu.k.d up, so you need to look on the speakers to see if there is a fuse that is blown that needs to be replaced.  If you got sound coming through, then disconnect them and hook them back to the original stereo making sure you got a good connection and all the wires are in good and tight.  Then turn your stereo on and go through the various channels like Tuner, Tape Deck, Aux, and DVD to see if you get any sound.  Also turn the volume knob up. If you don't get any sound after all this, you know there is something wrong with the stereo your using.
Oct 29, 2009 | Sony STR-DE685 Receiver
Getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Mar 09, 2009 | Televison & Video
Installing a cd player dp-87 on a component stereo
Its easy i think your chinch cables are not good try with other pair of chinches and if it not work try to change the speakers from a to b position on your amplifier if that doesnt work probably its the one chanell on your cd is not working.
Jun 14, 2008 | Audio Players & Recorders
My sony 27 Trinitron KV27FS100 has a great picture but no sound
HELLO. SOUND'S LIKE U HAVE A BAD SOUND BOARD.!!! U CAN HOOK UP TO A HOME STEREO AND GO THROUGH IT FOR YOUR SOUND.!!! GOOD LUCK!!! LET KNOW IF THIS HELP'S YOU.
Jun 05, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No sound
have you checked the connections and what is hooked up to the tv do you use a receiver or surround station to produce sound and did this just happen? please more info.
May 27, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
Dec 30, 2007 | Televison & Video
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
