Question about Craftsman 25cc Gas Line Trimmer
Im having trouble starting my sovereign petrol mower
Im trying to pull cord but only comes ot so far....
My 4 stroke petrol lawnmower engine won't start - where's the problem?
Hi try a new spark plug check if it's got petrol check for spark put the lead on the plug before U put it in hold the side of plug on the mower & pull the cord to c if it's got spark.. check for compression put your finger over plug hole & pull the cord if it's got compression it should push your finger away good luck
Nov 16, 2016 | Garden
Why does the pull cord is hard to pull and lawn mower won't start.
im betting the safety handle is not down far enough and is allowing blade brake to drag , also it's holding out ign ckt from working as well , those cables stretch all the time
Jun 18, 2014 | Poulan Pro " Pro" Self Propelled Mower
Masport 4 stroke mower...started it up and it worked for a couple minutes with a strange rattling growling noise.. Oil ok and petrol filled but the mower just shut it's self down and im not sure w
It will run for a few minutes and then shut down?
Lets ignore the growl for now. Loosen Gas cap and see if it will keep running. The rattle might be in the pull cord mechanism..possibly not related to stalling issue
Dec 03, 2012 | Garden
MY DAUGHTER HAS A SOVEREIGN SV40, CLASSIC XC35 PETROL LAWN MOWER, AND THE CLUTCH CABLE HAS BROKEN. I WOULD LIKE TOP KNOW WHERE I CAN PURCHASE A REPLACEMENT. I'VE TRIED THE WEB WITHOUT SUCCESS. CAN YOU...
As far as i remember the SV40 was a non self propelled mower, it will only have an opc cable ( engine brake cable ) this is part no. 531206026, in the UK the parts are distributed through Flymo.
May 14, 2011 | Garden
CHAMPION VANTAGE 35 PETROL LAWN MOWER
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
Apr 14, 2010 | Garden
I need a replacement wheel for a sovereign petrol mower. Any idea where I can get one from?
http://www.frankballantyne.co.uk/SPAREPARTS.php
You might try the above link. They are in the UK and if they don't have they may be able to point you in the right direction
Oct 03, 2009 | Garden
We have a briggs and stratton sovereign petrol mower the pull cord has gone loose no give so unable to start mower
If I'm understanding you correctly, the pull chord is out and will not retract so you can pull again?
If this is so, I'm thinking that there may be some obstruction keeping your spring from returning the rope. The spring is wound like a clock spring. When you pull the rope, the spring wants to bring it back. Sometimes a twig or dirt or other type of abnormality might prevent the spring from retracting your pull rope.
You might need to loosen the engine cover to remove the obstruction.
Jun 27, 2009 | Garden
Brand new Pope Spitfire 40 lawnmower won't start
Caren,
Drain the fuel completely if it is older than 1 week. Make sure you undo the bolt at the bottom of the fuel bowl to ensure all old fuel is drained. Refill with fresh fuel (premium unleaded) and try again. If it still does not work then remove the spark plug and rest it on the metal of the mower while still attached to the silicone ignition wire. Have someone hold the cut out bar to the handle (as you normally would to run the motor) and pull the cord. You should see sparks being emitted from the spark plug. (Make sure there is no fuel nearby) If you cannot see any sparks then replace the spark plug with a new one and repeat this process. If you still cannot see any sparks being emitted after attatching the new plug to the silicone wire, resting it on the metal of the mower, and pulling the cord to start it as you normally would, the mower will need to have the resistor and capacitor checked by a professional repairer as no spark is being generated.
Good luck.
Allan
Jun 06, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
121 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
